e4od problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2010, 11:56 PM   #1
camccardell
tiger blood
camccardell's Avatar
Default e4od problems
Well, I went to take my truck out for a test drive to test all the fun parts the other day, and everything went well except for a exhaust leak.
Well I ended up ripping the whole exhaust off and putting on new headers and a 3" system with no cat for now.
FYI it is a 95 f150 5.8 and it hasn't been running for over a year, due to engine replacement and 1 ton upgrades.
Well I went to take the truck out again after the new exhaust was on and the truck did not want to shift into 2nd gear. It finally did with a bang and bucked me prety hard and the OD light started flashing and the check engine light came on.
Pulled the code and it was for a bad MLPS. I went to pull it off to clean the thing, and it came off in pieces.
I put a new one on, but it is still doing the same thing.
Any ideas?
Old April 11th, 2010, 12:15 AM   #2
MilwaukeeF350
Dan
Is Speedometer stay straight or it bounce like this. YouTube- trouble with Ford speedometer it bounce itself.
then check vss sensor, tone ring on gear, and wiring on vss sensor.
Old April 11th, 2010, 12:18 AM   #3
Tom
Because racecar
Tom's Avatar
Any ideas?
Was there a speed sensor (on the top of the pig) on the rear differential that you removed? Does the new rear dif have that sensor? If not, there is your problem.
*edit I just looked at your build thread, it looks like it is plugged in.
x2 on what milwaukeeF350 said
Tom is online now   Reply With Quote
Old April 11th, 2010, 03:49 AM   #4
Never_Evil
Did you get a NEW one and redo the plug end, or a new to you from a junk yard and just slap it in?
Old April 11th, 2010, 11:43 PM   #5
camccardell
tiger blood
I left the sensor that was on the axle when I got it, and installed a new pigtail since I broke the original off when I tried to pull it from the 8.8
I can go get the sensor from the 8.8 and swap em out. See what happens.
I watched the video and it isn't doing anything like that. When I was up around 50mph it would sway left and right by a few mph, but no more than 3 or 4.
Old April 18th, 2010, 11:26 PM   #6
camccardell
tiger blood
no change. Open to suggestions
Old May 3rd, 2010, 12:08 PM   #7
camccardell
tiger blood
well I'm still getting a 452 code and I purchased a new sensor. Still nothing changed.
Old May 4th, 2010, 09:16 AM   #8
Tom
Because racecar
Tom's Avatar
What is the definition of the 452 code? I just looked it up and it is telling me it's for a low fuel pressure.
Did you replace the connector for the mlps when you changed it? is the wiring corroded? Did you forget to hook up a ground when you put everything back together?
Old May 4th, 2010, 12:41 PM   #9
masterbeatty
masterbeatty's Avatar
if you go to fullsizebronco.com theres tons of info for these e4od i had alot of problems in the wireing and they had all the info to sort it out.
Old May 8th, 2010, 05:16 PM   #10
camccardell
tiger blood
code means little or no responce from the VSS
posted on the fsb site as well, and it is looking like it might be the engine computer.
Old May 9th, 2010, 10:10 AM   #11
masterbeatty
did you check the wires to and from by chance. Maby one is pinched or you have a bad ground somewhere.
Old May 9th, 2010, 05:09 PM   #12
camccardell
tiger blood
yep, I did and contnuity looks good. I would check the pcm, but I do not have a breakout box.
thanks though
Page generated in 0.20234 seconds with 59 queries
