Transmission problem - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2010, 05:25 PM   #1
Jeepunk95
Default Transmission problem
OK so i did something against my better judgment and changed trans fluid in my Jasper 4l60e wiht over 150k on it this was bad idea #1. Any how drove it fine for about 1k miles or so since then no problems till today first time its been driven since last trailer pull. Drove to the gas station all was ok on the way home started getting a really bad flare up in RPM between 2nd and 3rd got home realized it appears the rear trans seal blew out checked the fluid it was way over full oops. ok so drained some fluid checked again all ok. The problem is while idling in drive or reverse i hear a clicking and bad noise coming from transmission mind you when i drianed the fluid it was very hot!! smoking.
Well basically now ive figured i need to either rebuild or replace leaning towards replace because im thinking the clicking noise i here is possibily broken planetary set in trnasmission. any input owuld be appreciated. thank you.
Jeepunk95 is offline   Reply With Quote
Old April 22nd, 2010, 11:16 PM   #2
Lousypirate
Whoop Whoop
Lousypirate's Avatar
sounds more like sun gear to me? much easier to break, buddy of mine grenaded the sun gear in his 4l60e...
Old April 22nd, 2010, 11:18 PM   #3
Junkyard
Junkyard's Avatar
if you want a new one let me know i work at a trans shop and can prolly get you a 100% rebuilt one for like $600
Junkyard is offline   Reply With Quote
Old May 1st, 2010, 09:42 PM   #4
Jeepunk95
ok thanx for the replies i will keep you in mind junkyard but right now the u-pull it LKQ yard in southbend said they will sel ltrans and tc for 134.00 so maybe enough to get by for now while i rebuild my old one.
Page generated in 0.22906 seconds with 35 queries
