351 W Flywheel/Clutch/Presure Plate? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 10th, 2010, 02:17 PM   #1
Hoofinit
Hoofinit's Avatar
Default 351 W Flywheel/Clutch/Presure Plate?
I have a 86 351W HO has an AOD, I am putting a ZF 5 spd on it. When I got the tranny I didn't get the Flywheel assembly as it came off of a 300 I6. Anyway I have gotten mixed answers, looking for some clarity if 5.0 and 5.8 are the same. I just purchased a 157 tooth 11" Flywheel clutch and pressure plate, will this work? I have pic's if that will help.
Thanks,
Tim
Hoofinit is offline   Reply With Quote
Old April 10th, 2010, 02:49 PM   #2
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
A 5.0 and the 5.8 have a different counter weight built into the flywheel/flex plate so no you cannot use the 5.0 but the older 302s use the same weight as the 351w/5.8
Old April 10th, 2010, 03:03 PM   #3
Hoofinit
Hoofinit's Avatar
I knew part of the issue was internal and external balancing, just never got a good answer of which is which. I went to the LUK site, it says 5 speed but doesn't specify a motor,(see link below). I bought this cheap enough I couldn't really lose, it's brand new in the box, and I should be able to resell it easy enough.
http://catalog.brakewarehouse.com/it...TEMS&weight=27
Old April 14th, 2010, 02:35 PM   #4
insaneoffroader
insaneoffroader's Avatar
This doesn't answer your question but good info for ya.
http://classicbroncos.com/tech/budget-zf-transmission
OK this might
http://www.novak-adapt.com/knowledge...l_block_v8.htm
If parts ain't flyin' you ain't tryin'
insaneoffroader is offline   Reply With Quote
Page generated in 0.22708 seconds with 35 queries
