***SOLD*** Dodge/ Jeep magnum V8 NV3500 4x4 Tranny with Hurst shifter - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 8th, 2010, 01:25 AM   #1
snodevil
snodevil's Avatar
Location: Berkley, MI 48072 / Indian River, MI 49749 (cottage)
Send a message via AIM to snodevil Send a message via MSN to snodevil
Cool ***SOLD*** Dodge/ Jeep magnum V8 NV3500 4x4 Tranny with Hurst shifter
I have a 97 Dodge NV3500 4x4 manual 5 speed trans from behind a 318 V8 dodge magnum motor out of V8 Dakota/ Ram (will fit the 360 also and maybe v6 magnum ). Bellhousing is part of trans case. 23 spline output (same as jeep tranny) with six bolt mounting pattern. Uses same throw out bearing, clutch fork and slave cyl. as a jeep. Uses a larger 11" clutch for the larger V8 flywheel.
This trans has a Hurst shifter on it as well. Has wide ratio 4.1 first. Rated to handle around 300 + ft/lbs. Spins fine and shifts through all gears great. Currently in my TJ behind a 318 not driven on yet. I just filled it with new fluid, so it's ready to go. I just decided I want to put in a trans with a granny first gear. Good tranny to use to swap in a v8 magnum motor into a jeep while being able to use a jeep t-case. Or just use to replace a tranny in a ram or dakota, or be slick and use this to do a manual conversion in a v8 zj, durango, ect.
Hurst shifter goes for nearly $300 alone.
$550 for tranny and shifter. SOLD
PM me please
I would trade this towards dana 60 parts (gears, lockers, shafts, other goodies), 29 in/31 out klune v, TJ rear stretch corner blanks, link parts, TJ stretch tank, maybe others.
snodevil is offline
Old May 25th, 2010, 03:12 PM   #2
snodevil
snodevil's Avatar
up
snodevil is offline
Page generated in 0.23791 seconds with 29 queries
