96 f-350 - replace key ign. tumbler etc. - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 7th, 2010, 10:07 AM   #1
Pokerob
hug life
Pokerob's Avatar
Default 96 f-350 - replace key ign. tumbler etc.
My bro in law has a ford that he used for his business but has been sitting for a year.
he lost the key and now needs to get in and replace the tumbler/key assmbly.
I have done this to my cj's more than once...is it pretty much on the same difficulty level??
Old April 7th, 2010, 11:16 PM   #2
Yota Bill
generally, Fords are much easier...put the key in, turn it on, push the small button in that is accessable through a whole in the bottom of the column, pull ignition tumbler out, slide in new one (after making sure the key is in the "on" position and the button is depressed) and turn the key off...only tools needed are a small straight pick or screwdriver, and, of course...the key
without the key, your going to have much more fun...own a slide hammer?
might be better off trying to get the key code and have a key cut from that
Old April 8th, 2010, 08:55 AM   #3
Pokerob
hug life
Pokerob's Avatar
seriously?? that sucks . We dont have the key which is why we are trying to just replace it.
i will get the vin and see if ford will just cut a key.
Old April 8th, 2010, 09:00 AM   #4
Flexin' XJ
Flexin' XJ's Avatar
Ford should be able to cut a key depending on when their year cut-off is. GM can't make keys before a certain year.
He will need to bring proof of ownership to the dealer to have the key made. Registration or title should work.
Also depends on whether or not the cylinder has ever been changed before. If it has, he would have to buy a new ignition cylinder and key.
Flexin' XJ is offline   Reply With Quote
Old April 8th, 2010, 09:01 AM   #5
Bc1980
finding they key is the best way. is a 96 the rounded body style?
if it is you will be screwed because of the factory seurity. and have to have it programmed by a locksmith that can do it or someone with a programmer.
i would call locksmith i think they charge around 80 for new keys and reprogram.
Bc1980 is offline   Reply With Quote
Old April 8th, 2010, 09:04 AM   #6
Pokerob
hug life
Pokerob's Avatar
key is long gone. im not sure if it has security or not.
thanks for all the help guise. This will be up for sale soon after we figure the key issue out and get it running again.
Old April 9th, 2010, 12:01 AM   #7
Yota Bill
you can use a punch to basically force that reatining pin in, which will destroy the old tumbler, but should not damage the column at all...remove the plastic on the bottom of the column, find the tumbler release pin hole (bottom side directly under tumbler) and drive that pin in with a hammer and small punch...IIRC, when you get the pin pushed in far enough to break the lock bar, the face of the tumbeler will actually pop off, and the tumbler will seperate into a couple pieces, so you will then have to dig out whatever is left in the housing, may have to use a screwdriver to turn the rack into the "On" position, and then remove the rest
you will need to turn it into the "On" position anyway, to install the new tumbler
Page generated in 0.26380 seconds with 44 queries
