96 f150 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 6th, 2010, 06:10 PM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default 96 f150
So i'm a Chevy guy and don't know to much about ford. So my uncle calls me and asks if i can come look @ his truck. he had the local Ford shop work on it. He said he heard a loud popping sound when he drove and figured it was the exhaust so he took it in. The ford dealership said a spark plug broke off and they had to get it out of the head. So i could only assume that the spark plugs haven't been changed in quit a long time. Now it's doing it again he said. Now he wants me to put some new heads on it. How hard is it to change the heads out of a 96 F150 w/ a 5.0 in it?
Old April 7th, 2010, 10:01 AM   #2
Bones
Bones's Avatar
so when it was at the dealership the owner didn't request to have all the plugs changed?
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 7th, 2010, 12:56 PM   #3
Hoss Blazer
!SPARTY ON!
Guess not. I don't know how they got the broken spark plug out.
Old April 7th, 2010, 04:00 PM   #4
muddywater
Stacks bring the awesome
muddywater's Avatar
Send a message via AIM to muddywater Send a message via Yahoo to muddywater
5.0 is a simple job. very easy. make sure its a 5.0 though not a 4.6 or 5.4 those get a little bit more compicated. if your putting new heads on it pry get some new manifold bolts as well you will probably break some taking them off. just pull them off the heads not off the pipes. its easier to just break them off in the head then having the studs break off and have to drill them out to put the exhuast y pipe back on.
while your down that far you could take a little bit more apart and put a timing chain and sprockets in it too. unless its somewhat low milage.
muddywater is offline   Reply With Quote
Page generated in 0.18005 seconds with 35 queries
