locker? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 6th, 2010, 11:55 AM   #1
2fst4you
2fst4you's Avatar
Default locker?
looking to put an aussie locker in my d44. Do i need a ring and pinion shop to install it or could i do it?
Old April 6th, 2010, 12:11 PM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Easy as pie, as long as you can disassemble the axle of choice that it is going in.
Old April 6th, 2010, 12:12 PM   #3
2fst4you
2fst4you's Avatar
i can disassemble an axle and its going to be my d44 thats already out of the jeep but will the position of the gearing get messed up at all?
Old April 6th, 2010, 12:14 PM   #4
BigBlockBlazer
Axle breakin' 101
Nope. If the axle is already out you can easily work on it without removing the carrier at all.
Old April 6th, 2010, 12:17 PM   #5
2fst4you
2fst4you's Avatar
so you just remove the spider gears, roll pin and etc. while the carrier is in the diff then slip the locker in?
Old April 6th, 2010, 12:18 PM   #6
Mr. Beefy
BFT!
Mr. Beefy's Avatar
My 44 I had to take the ring gear off to get the pin out.
Old April 6th, 2010, 12:20 PM   #7
2fst4you
2fst4you's Avatar
but did u keep the carrier in? and will i be able to install my locker in my d44 without changing the alignment of the gears?
Old April 6th, 2010, 12:20 PM   #8
BigBlockBlazer
Axle breakin' 101
It's still not a big deal if you have to remove the carrier and ring gear, just bolt it back together the way it came out. And use Locktite.
Old April 6th, 2010, 12:22 PM   #9
2fst4you
2fst4you's Avatar
It's still not big deal if you have to remove the carrier and ring gear, just bolt it back together the way it came out. And use Locktite.
will it just slip into where it was and will the alignment of the gears stay the same?
Old April 6th, 2010, 12:23 PM   #10
BigBlockBlazer
Axle breakin' 101
It will not mess with your gear settup as long as you pay attention when you disassemble things. I.E.- make sure you put any shims that come out back where they go. The pinion will not be affected.
Old April 6th, 2010, 12:25 PM   #11
2fst4you
2fst4you's Avatar
ok that makes sense cool thanks!
If anyone wants to help me install a locker somewhere down the line so i dont mess it up let me know thanks.
Cameron
Old April 6th, 2010, 12:27 PM   #12
BigBlockBlazer
Axle breakin' 101
Take your time and it will be fine. Your new locker should come with install instructions, if it doesn't download them.
Old April 6th, 2010, 12:37 PM   #13
2fst4you
2fst4you's Avatar
ok cool thanks
Old April 6th, 2010, 09:20 PM   #14
thrca
UberGeek
thrca's Avatar
I was a little apprehensive the first time I took it apart, but after I saw how simple it was, I have done about 10 of them without a problem. Its pretty easy.. If you have to pull the carrier and ring (I did on my D30) you just need to mark where the ring was in relation to the carrier and put it back the same way it came off (and torque the bolts properly).
thrca is offline   Reply With Quote
Page generated in 0.20963 seconds with 65 queries
