Ford 10.25 stergling have chip on gear's ring - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2010, 01:55 PM   #1
MilwaukeeF350
Dan
Default Ford 10.25 stergling have chip on gear's ring
Well member from here. He want 4.10 from me so he gave me this 3.55
History it came from 95 F250 ext cab with 351W E40D it have about 100K miles.
I would say it isn't bad just wear little.
I notice chip on gear ring which make me concerned about that. I don't think pinion gear would reach that chip.
Can it weld with arc welder?
ignore white circle it wrong. Look at red circle.
Old April 3rd, 2010, 10:19 AM   #2
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Inspect the tooth carefully for cracks. If there are not, just run it. The chip is not in the normal contact zone of the pinion gear so it should be fine. You can use a medium grit disc to polish the chip out so that there are no jagged edges.
Old April 4th, 2010, 01:21 PM   #3
Bones
Bones's Avatar
yup, clean up the chip and run it
Inviscid Motorsports
Motorcity Machines
Branik Motorsports
Maxxis Tires
Raceline Wheels
PAC Racing Springs
Joint Clutch and Gear
Old April 4th, 2010, 05:46 PM   #4
MilwaukeeF350
Dan
I read ford manual book that I got from college.
It say it chip is end of gear you should be fine since Pinion wouldn't reach that.
Pinion gear does have wear you put your finger on tooth you could feel little bump.
I was wonder if I put 90w90 it too thin so it would wear out little fast if I use like 90w120 It would last longer? It will see highway daily.
Trenton to Fenton or Alpena.
Old April 5th, 2010, 09:04 AM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Throw that book in the trash
Didn't I just say that?
Use 80w90, you'll be fine so long as the rest of the setup is okay.
Page generated in 0.25176 seconds with 38 queries
