SOLD! 42" Craftsman Snow blade $125 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2010, 01:56 PM   #1
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Default SOLD! 42" Craftsman Snow blade $125
This is a Craftsman Tractor plow .it has a universal Mounting head with adjustable blade angle from the seat. its in real nice shape and not all ate up by time. has a good cutting edge and good skid legs. with the mount it has it could be installed on any flat mounting surface like a tractor, quad, etc..
also have chains for 18 x 8 . if you buy the blade I will make you a deal.
12/17 PRICE DROP! $125
Yetti
Yetti is offline
Old May 6th, 2010, 09:24 PM   #2
brewchief
Do you have any other brackets off the tractor or is it what you see what you get? Is there a model number on it anywhere? I'm interested as long as I don't have to spend a ton to make it fit my crapsman tractor.
brewchief is offline
Old May 7th, 2010, 06:07 PM   #3
Yetti
Yetti's Avatar
I do not have any brackets. the blade is all self contained. however I was told by one guy who looked at it they make an "Adapter" to fit other machines and it looks like a big letter Y that goes under certain machines to push from the rear axle.
I actually measured the bolt pattern for the mounting and the pattern is approx 6 1/2" wide center to center and has 3 sets of oval holes. is you figure from the top down its about 2" on center going down the pattern. if you have a machine with a flat mounting surface then it should be easy to hook up.
Yetti
Yetti is offline
Old October 4th, 2010, 09:19 PM   #4
Yetti
Yetti's Avatar
couple of new pics to show the mounting plate for this one.
Yetti
Yetti is offline
Old December 8th, 2010, 04:55 PM   #5
Yetti
Yetti's Avatar
bump
Yetti
Yetti is offline
Old December 17th, 2010, 06:10 PM   #6
Yetti
Yetti's Avatar
bump
Yetti
Yetti is offline
Old December 17th, 2010, 10:06 PM   #7
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Does the flat plate mount to the front, or the bottom of the tractor? Thanks.
zook94 is offline
Old December 17th, 2010, 10:11 PM   #8
Yetti
Yetti's Avatar
its a front flat plate. any vertical surface thats solid should support it.
Yetti
Yetti is offline
Old December 17th, 2010, 10:14 PM   #9
zook94
Resident Jerkoff
zook94's Avatar
Any idea what it weighs?
zook94 is offline
Old December 17th, 2010, 10:24 PM   #10
Yetti
Yetti's Avatar
probably 40-50 pounds
Yetti
Yetti is offline
Old December 31st, 2010, 08:38 PM   #11
Yetti
Yetti's Avatar
bump for the new year!
Yetti
Yetti is offline
Old January 8th, 2011, 11:00 AM   #12
Yetti
Yetti's Avatar
bump
Yetti
Yetti is offline
Old January 12th, 2011, 01:51 PM   #13
shortnmouthy1
2 trk mind
shortnmouthy1's Avatar
I've got a craftsman tractor. 19.5 hp. do you think i can just mount it or do i need something else?
shortnmouthy1 is offline
Page generated in 0.21546 seconds with 62 queries
