drivers side axle ujoint 79 bronco replacement - Great Lakes 4x4. The largest offroad forum in the Midwest
Old April 2nd, 2010, 09:07 AM   #1
JoshuaCripe
JoshuaCripe's Avatar
Default drivers side axle ujoint 79 bronco replacement
im going to attempt this after work today......any advice? i'll probably resort to the hammer and socket method..but never did a ujoint before always had cv axles..any help would be great ..thanks
josh
JoshuaCripe is offline   Reply With Quote
Old April 2nd, 2010, 12:14 PM   #2
camccardell
tiger blood
camccardell's Avatar
put it in a vice. Don't tightent it, but let 2 of the ears sit over the jaws. Tap the yoke with a hammer and it should pop the cap off. be sure to get the clips off first!!!
Old April 2nd, 2010, 03:16 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
if your vice is big enough you can press them out easy that way. small socket on one side. big socket on the other, then tighten. pushes them right out usually.
ball joint presses work good too.
or a bfh can do it.
if its on a late 80's to early 90's gm product take it in. injection plastic retained joints suck to change.
the last one i did i left the map gas torch burning on it and left. after a while i heard a loud bang. took a while though.
Old April 5th, 2010, 06:27 PM   #4
JoshuaCripe
i ended up snapping all 5 studs that hold the hub to the knuckle and the damn hub still wouldnt come off....so i cut the upper and lower balljont and pulled the whole assembly...
my buddy came over and did a dana 44 outta a chevy before he hit the hub on the smooth shaft part and it came a[art like its suppose to.
so i have a new ujoint, 5 new hub to knuckle studs upper and lower balljoints lol.But i ran it pedal to the floor with no problems all day at bundy.
Page generated in 0.20747 seconds with 35 queries
