My 00 xj - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old October 24th, 2013, 06:22 PM   #21
Wramblerguy
Wramblerguy's Avatar
Originally Posted by SET2JET View Post
any more thouhts on the true-trac??
I have one in my jeep and it is awesome for turning awesome for mud and trails
It's basically awesome until you lift a tire or are hard in the rocks
It is what it is which is a posi. I know of a few people that run them with automatics(I run a manual) and they like them more but they can apply some brake pressure to help it lock up but I don't have 3 feet
They are practically indestructible and should help your stock shafts live though
I would definitely recommend some spicer joints too if you aren't already running them
3rd generation jeeper
Old October 24th, 2013, 07:33 PM   #22
TCxOUTLAW
TCxOUTLAW's Avatar
TCxOUTLAW is offline   Reply With Quote
Old November 7th, 2013, 06:53 AM   #23
amc78cj7
amc78cj7's Avatar
So you cut off the rockers and installed rectangular tube sliders? How/where is that tubing welded to the unibody?
I'm not quoting idiots who promote unsafe recovery strap techniques anymore. :miff:
amc78cj7 is offline   Reply With Quote
Old November 11th, 2013, 03:20 PM   #24
jeepkid984
The Violator
I myself just did to rec tube rockers. They are welded all the way around and then tie into the leaf spring mounts and once I get my plating on. They will tie into the unibody with 2x2x .250 square tube just under the A and B pillar. Once it was welded up to the point we got it now, we wrer able to jack the xj by the hoist with no problem. Overkill is in order though, so extra bracing is a must imo.
jeepkid984 is offline   Reply With Quote
Page generated in 0.24051 seconds with 35 queries
