Need help... 78 CJ7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 30th, 2010, 09:03 AM   #1
Looking4aJeep
Looking4aJeep's Avatar
Default Need help... 78 CJ7
Just bought my first Jeep, 78 CJ7 has 304 3sp. Looking for options to make it sit wider. What are some suggestions for axles or anything else anyone can think of. Looking for something for trails mostly. Any help would be greatly appreciated.
Looking4aJeep is offline   Reply With Quote
Old March 30th, 2010, 09:15 AM   #2
EASY STEP
EASY STEP's Avatar
Location: HOME IS CADILLAC MI, WORK IS IN ELKHART INDIANA USA
Well one of the simplest thing to do is go with a wider wheel with a large off set to make the stance wider, one thing that conserns me when someone new to the sport of jeeping,they get way over their head in developing a jeep that they think will run down the road like their stocker, and be really disapointed in the amount of money they have put into their jeep and it drives like crap for what they want to use it for, so be really careful when building a jeep dont get in over your head mechanically, Its easy to really screw up a good thing!
Wider tires and simple lifts keep a guy or gal that is limited mechanically, challenged enough!
Just for straters keep it simple and have a blast!
EASY STEP is offline   Reply With Quote
Old March 30th, 2010, 09:30 AM   #3
bandit305
cj7 low budget fun
bandit305's Avatar
how true
bandit305 is offline   Reply With Quote
Old March 30th, 2010, 10:07 AM   #4
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Mid 80's cj wide track axles and 3.5" backspacing wheel. You don't want to go with to little of backspacing as it puts more leverage on the wheel bearings and larger tires they will wear out or break faster.
Old March 30th, 2010, 10:46 AM   #5
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Yeah, before you start thinking full width axles, hydro steering and Detroits front and rear, really look at what you are going to do this your rig. Besides, learning to wheel with opens and narrow axles will make you that much better later on.
Mulely is offline   Reply With Quote
Old March 30th, 2010, 11:38 PM   #6
PavementPounder
PavementPounder's Avatar
The "simplest" thing to do is add spacers. I wouldn't do that.
I wouldn't go and blow money on new wheels, either.
The WT swap is pretty easy and it opens the door for you to improve your gearing at the same time.
Page generated in 0.27594 seconds with 41 queries
