Dakota torsion bars - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 29th, 2010, 04:34 PM   #1
Jbrandon
Default Dakota torsion bars
I have a 2000 dodge dakota that i cranked the torsion bars i didnt get a perfect measurement but i would say it lifted it about 2". I found on ebay they sell torsion bar keys for a front leveling kit that say they will lift the front 2-3". If i get these keys will it lift the truck anymore than cranking them already has?
Thanks ahead of time.
Jbrandon is offline   Reply With Quote
Old April 1st, 2010, 12:25 AM   #2
vince43m
vince43m's Avatar
no it will not it does the same thing as when u crank them you should only go 8 turn witch is 2 " any more would make to much stress on the bar youll start breaking things
if you wanna lift the back just buy the beltech 6400 shackels and install thoes the are fora full size chevy and are a drop for them
-Vince
vince43m is offline   Reply With Quote
Old April 1st, 2010, 12:26 AM   #3
vince43m
vince43m's Avatar
-Vince
Old April 7th, 2010, 02:26 PM   #4
brian318
Is the Durango and Dakota have the same leaf spring suspension? I see that the Durango Guys are using the Shackle kit, but didn't look like anyone with Dakotas were doing the shackle. Is it true that the belltech 6400 will raise the rear 2" of a Dakota? or just a Durango?
Thanks for the help
Edit-
Originally Posted by garfld66 View Post
and how much lift will they give is this better then blocks?
They won't give you any lift, on your Dakota.
As stated, Durango springs are mounted underneath the axle. Whereas, they are on top of the axle on a Dakota
Your options are blocks, add-a-leaf, or possibly re-arched springs.
Last edited by brian318; April 7th, 2010 at 02:31 PM. Reason: I found the answer on the interweb...
brian318 is offline   Reply With Quote
Page generated in 0.19400 seconds with 35 queries
