Converting rear Ford D60 to 6x5.5 and disc brake? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 29th, 2010, 08:22 AM   #1
TacomaJamie
TacomaJamie's Avatar
Default Converting rear Ford D60 to 6x5.5 and disc brake?
I have a late 70's single rear wheel full floating Ford D60 rear axle that needs to be converted to 6x5.5 and disc brake. It is going to be narrowed a bit so the shafts will be custom anyways and I assume could just be ordered to 6x5.5. What are my options and could any of you guys provide some recommendations/direction aside from the 1200.00 kit that "solid axle" provides. If possible I'd like to keep it full floating.
Thanks in advance!
TacomaJamie is offline   Reply With Quote
Old March 29th, 2010, 08:32 AM   #2
PavementPounder
PavementPounder's Avatar
Why would you specify a bolt pattern for a full-floating shaft?
Old March 29th, 2010, 09:41 AM   #3
TacomaJamie
I would like the wheel bolt pattern to be 6x5.5 to match the front dana 44.
Old March 29th, 2010, 09:54 AM   #4
kj kyle
kj kyle's Avatar
on a full floater, the wheel doesnt bolt to a shaft, it bolts to a hub.
therefore when you order a shaft, its not bolt pattern specific
kj kyle is offline   Reply With Quote
Old March 29th, 2010, 09:56 AM   #5
kj kyle
kj kyle's Avatar
maybe this would work for you.
http://www.solidaxle.com/ProductCart...&idcategory=11
but then you would have to run a double splined shaft, and a slug.
Old March 29th, 2010, 10:10 AM   #6
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
Many dollar cheaper to buy new wheels in a 8 lug flavor and sell the old.
Old March 29th, 2010, 10:17 AM   #7
kj kyle
kj kyle's Avatar
good point. dana 44 would be super easy to convert to 8 lug. then just by new rims
Old March 29th, 2010, 10:38 AM   #8
95geo
newbie
95geo's Avatar
This is the cheapest and easiest way to get a 5.5" circle BP into a FF axle.
Convert it to SF. Chances are, you dont need the strength of a FF axle and its more work to get a 35 spline shaft in a FF 60 than it is to cut the ends off and weld SF ends on.
Old March 29th, 2010, 11:07 AM   #9
TacomaJamie
Thanks for the clarification guys. 95 Geo, can you elaborate on what you've got going on there? What did you get the semi-floating ends off of that you welded on? What would my options be for disc brakes at that point?
Old March 29th, 2010, 11:39 AM   #10
95geo
newbie
95geo's Avatar
moser shafts
ballistic 3" slip on housing ends opened up for 3 1/8" tube
dodge ram 13" rotors
wilwood D52 aluminum replacement calipers, dual 2.0" piston
You would have to pick your rotor for bolt pattern and wheel size.
The setup above is for 5 on 5.5" and 17" wheels. Tried balancing component quality with price and performance. I think we chose the right components to meet the goal. Most people would choose different calipers though. ~$200 each with pads. The pads are wilwood brand and one of their middle of the road compounds good for cold performance. The brakes should be as good as a new vehicle with 30" tires compared to many other vehicles that have brakes that are barely enough to stop with big tires.
Page generated in 0.24039 seconds with 53 queries
