removing factory decals from plastic - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 29th, 2010, 08:10 AM   #1
jeeperstrudie
AdvoCare Distributor
jeeperstrudie's Avatar
Send a message via Yahoo to jeeperstrudie
Default removing factory decals from plastic
My daughters PW50 decals are looking pretty worn. I would like to remove them in order to clean the bike up a bit and then look for some replacement decals.
Can anyone give me some helper idea's on how to get the old decals off the plastic parts?
jeeperstrudie is offline   Reply With Quote
Old March 29th, 2010, 08:22 AM   #2
mikesova
My 4x4 is a Subaru.
mikesova's Avatar
hair dryer to get the stickers loose then wd40 to get the residue off. This has worked for everything I've ever done it with (on metal), although, I'd be careful with the hairdryer to make sure you don't warp the plastic.
Old March 29th, 2010, 08:24 AM   #3
JohnL
Go until it breaks.
JohnL's Avatar
Send a message via AIM to JohnL
Use a hairdryer or heat gun set on low to not warp the plastic and then use goo gone to get the rest of the residue off.
JohnL is offline   Reply With Quote
Old March 29th, 2010, 08:36 AM   #4
wheelinblazer98
wheelinblazer98's Avatar
goo gone
wheelinblazer98 is offline   Reply With Quote
Old March 29th, 2010, 12:10 PM   #5
lososjoyride00
vehicle abuse specialist
lososjoyride00's Avatar
you can get the white spots out of the plastic with a heat gun too. and remember to use scotchbrite and contact cleaner to clean the plastic before putting on the new graphics. a quick way to get off the decals is a power washer. always works way to good on my bike.
lososjoyride00 is offline   Reply With Quote
Old April 1st, 2010, 08:04 PM   #6
04PSD
aka Langford
04PSD's Avatar
X2 with the power washer...I accidentally found that out while trying to blast the mounds mud off of my wolverine, the mud came off...and so did the decals. But I have also used the hair dryer trick, heat up the decals a little, grab a corner with your finger nail and start peeling. Clean up the residue with a microfiber towel and some WD-40.
04PSD is offline   Reply With Quote
Page generated in 0.23842 seconds with 41 queries
