no spark 304 help - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > General 4x4 Stuff > The recycle bin.
The recycle bin. Posts deemed annoying. If you see your post here, take a hint.
Old March 26th, 2010, 03:30 PM   #1
bandit305
cj7 low budget fun
bandit305's Avatar
Default no spark 304 help
Hi, I'm having a problem with my 304 it has no spark I replaced coil pack and has power going to it. but doesnt come out to the distributor(also replace the cap and rotor on the distributor) also replaced the modular.. Thanks for any help 81 cj7 304 no points in distributor
bandit305 is offline   Reply With Quote
Old March 26th, 2010, 03:43 PM   #2
bandit305
cj7 low budget fun
bandit305's Avatar
p.s I checked fuses are (good) any help thanks
Old March 26th, 2010, 06:10 PM   #3
bandit305
cj7 low budget fun
bandit305's Avatar
bump
Old March 26th, 2010, 06:47 PM   #4
bandit305
cj7 low budget fun
bandit305's Avatar
i have power going to the coil but none coming out what should I check next
thanks
Old March 26th, 2010, 07:57 PM   #5
bandit305
cj7 low budget fun
bandit305's Avatar
have pics in profile thanks
Old March 26th, 2010, 08:08 PM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Pick-up coil?
Old March 26th, 2010, 08:17 PM   #7
bandit305
cj7 low budget fun
bandit305's Avatar
where is the pic- up coil. I did replace the coil packthanks
Old March 26th, 2010, 08:21 PM   #8
Rob the plumber
The pick-up coil would be under the rotor. Can you take off the cap and post some pics of whats under there? The AMC stuff usually came with points and most of that stuff has been converted to some degree.
Old March 26th, 2010, 08:39 PM   #9
bandit305
cj7 low budget fun
bandit305's Avatar
more pics in profile thanks for the time
Old March 26th, 2010, 09:03 PM   #10
bandit305
cj7 low budget fun
bandit305's Avatar
bump for a cj
Old March 26th, 2010, 09:28 PM   #11
bandit305
cj7 low budget fun
bandit305's Avatar
well I put pics of the eng in the profile any help or suggestions would help thanks
Old March 26th, 2010, 09:46 PM   #12
bandit305
cj7 low budget fun
bandit305's Avatar
should I just upgrade the distributer and which would be easy and cheap lets say my bang for buck
Old March 26th, 2010, 09:56 PM   #13
anything old
run it
anything old's Avatar
alittle hammered right now but i had this problem with my 304 and it i was a ground wire. I dont have the connector you do but one of the wires running to the distributor had a direct ground to the battery it was tied into two hot wires that ran to the distributor. I could be way off but id double check your grounds.
anything old is offline   Reply With Quote
Old March 26th, 2010, 10:06 PM   #14
bandit305
cj7 low budget fun
bandit305's Avatar
thanks will double check in the morning
Old March 26th, 2010, 10:31 PM   #15
bandit305
cj7 low budget fun
bandit305's Avatar
bump for more help
Old March 26th, 2010, 10:59 PM   #16
jeepers48
jeepers48's Avatar
Check the solenoid yet? The 2 small studs.
X2 on a bad ground. One grounds the motor to the frame and the other from the motor to the firewall. I just went thru this on a YJ.
jeepers48 is online now   Reply With Quote
Old March 26th, 2010, 11:17 PM   #17
bandit305
cj7 low budget fun
bandit305's Avatar
thanks I'll check that out to. I just dont understand why i have power to the coil but it doent come out the coil but at this point I'll undo and redo cant hurt any more.
Old March 26th, 2010, 11:18 PM   #18
bandit305
cj7 low budget fun
bandit305's Avatar
ps put 2 coils on
Old March 27th, 2010, 12:16 AM   #19
bandit305
cj7 low budget fun
bandit305's Avatar
well one more bump so when I wake up.I can make a list to re check or check. and thanks 2 all for the help. pics are in profile if that helps. just dont know how to post them in a threads yet but I will learn.
Old March 27th, 2010, 10:09 AM   #20
cjric
cjric's Avatar
Try replacing the capacitor.
cjric is offline   Reply With Quote
Tags
no spark plz help
Page generated in 0.37804 seconds with 82 queries
