18HP Ranch King Garden tractor - Gone - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 26th, 2010, 10:13 AM   #1
FlamingTomato
You break it - You fix it
FlamingTomato's Avatar
Default 18HP Ranch King Garden tractor - Gone
Parked due to steering rack stripped out
Worked great as long as you turned right
has been stored inside - I am not sure why - but I did put it in the barn??
Briggs vertical shaft 2 cylinder
Ran well - minimal smoke - low compression when hot -
Steel hood and front end, 2 blade deck with mini center blade -
Starter is off, needed the starter gear for other mower - now I lost the starter.
May be able to find - no promises though.
This is the large rear tire Garden tractor style.
With the heavy duty rear axle 4 speed trans.
donation of High life gold can 30 pack appreciated
FlamingTomato is offline
Old March 26th, 2010, 06:45 PM   #2
bigbchevy
missmrgreenagain
bigbchevy's Avatar
can i get your address so i can map it thanks pm me
H.o.r.e
bigbchevy is offline
Old March 27th, 2010, 09:42 AM   #3
94jimmyjr
94jimmyjr's Avatar
i guess ill have to pass your 2.5 hours from me!
94jimmyjr is offline
Old March 27th, 2010, 10:20 PM   #4
FlamingTomato
Dan,
Thnx for the brews!
Page generated in 0.15406 seconds with 35 queries
