00 2500 ram/bearing warrantees - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2010, 07:52 PM   #1
95ram
Default 00 2500 ram/bearing warrantees
Does anybody know of a place that still has the 1-year warrantee agreement on wheel bearings?
For example, if you replace your bearing within that year… the 1 year warrantee will renew itself and you have another whole year to replace it.
I thought murrays used to do this but I cant remember for sure.
I have a ram with 13in lift and 42s as my daily driver I cannot keep affording to replace these things at $250-300 a pop
Any help is appreciated
Thanks GL4x4
95ram is offline   Reply With Quote
Old March 24th, 2010, 08:05 PM   #2
boggin-machine
boggin-machine's Avatar
you cheap bastard. for one dont daily drive on 42s and then bitch about it. for two why are you tearing them up so bad? for three. i bought mine at advance auto with a life time for my 99 for 227 out the door with abs
Old March 24th, 2010, 08:13 PM   #3
95ram
I guesll ill have to keep shopping around... the few places i called $250-300 was the price range depending on the manufacturer. but ill give advance auto a shout tomorrow.
as of right now this is my only means of transportation
not bitching. just looking for a little help thats all
Old March 24th, 2010, 08:15 PM   #4
Fullsize4life
Kicking Cancers ASS
Fullsize4life's Avatar
The ones for my 95 at carquest were 140 a piece.
Old March 24th, 2010, 08:32 PM   #5
bigchevymike
replaced one on a 04 today and was 259 shop cost!
bigchevymike is offline   Reply With Quote
Old March 24th, 2010, 08:33 PM   #6
95ram
thanks FS4L.
i called tonight but they were closed
appreciate the response
Old March 25th, 2010, 09:35 AM   #7
busyfixin
Balls Deep
busyfixin's Avatar
just got one for my 98 at autozone. 150ish, and one year warranty. advanced auto was 215.
Old March 25th, 2010, 09:45 AM   #8
JeepInABox
In too deep
JeepInABox's Avatar
All parts sold at the dealer are 1 year. Had a dealer only radiator fan relay($70) go bad after 340 days and got a new one free. Good thing I had the receipt. He also said I had another year on the warrantee.
Too bad your part will be crazy expensive from the dealer.
Old March 25th, 2010, 10:43 AM   #9
95ram
was this for a 1500 or 2500?
Old March 25th, 2010, 10:44 AM   #10
95ram
im not even gonna bother calling because i already know the price is going to be outrageous.
thanks for the response though
Old March 25th, 2010, 11:03 AM   #11
mhicks1017
mhicks1017's Avatar
these guys have the best bearings I ever bought. The company is even Michigan based.
http://www.wheelbearingsinc.com/index.cfm
mhicks1017 is offline   Reply With Quote
Old March 25th, 2010, 11:18 AM   #12
PavementPounder
PavementPounder's Avatar
NAPA was the last place I found that was offering some of the good brands with a lifetime warranty. Mopar was selling the exact same parts, but with only a 1-year.
Search Dodge Tech on Pirate and you will find the write-ups on how to use Ford parts to convert the Ram outers to spindles.
They are all over eBay. A lot of people buy from them.
Old March 25th, 2010, 12:10 PM   #13
95ram
i have never heard of this.
can you yourself go into more detail in regards to converting ford parts to the ram outter spindles?
thanks
Old March 25th, 2010, 12:11 PM   #14
busyfixin
Balls Deep
busyfixin's Avatar
2500. i dont play with that light duty shit if i can help it. at least not till i do a 4bt swap in a single cab half ton.
IIRC... the ford outers on a dodge uses the following...
chevy 60 outer shafts
ford TTB dana 50 spindles (redrilled to the dodge four bolt pattern hub pattern)
ford 60 hubs and bearings
01-02 ram 2500 rear rotors
or depending on your year, you may be able to use a complete ford ball joint 60 outer knuckle assembly including brakes and shafts, but i think the width is different. that way
Old March 25th, 2010, 12:14 PM   #15
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Definitely look into upgrading.....
Old March 25th, 2010, 12:14 PM   #16
busyfixin
Balls Deep
busyfixin's Avatar
FWIW, i think the wheelbearingsinc.com's part number is the same as the auto-zone one i just got.
Old March 25th, 2010, 12:16 PM   #17
busyfixin
Balls Deep
busyfixin's Avatar
i need to upgrade as well, i started gathering parts and was all ready to dive into doing the swap when i found that my 87 kingpin ford 60 spindles were too big, got fed up and bought a new advanced auto wheelbearing since they had one in stock and i needed my truck. figures as much, the other side took a poop about a year and 5 days from the other side.
Old March 25th, 2010, 12:17 PM   #18
busyfixin
Balls Deep
busyfixin's Avatar
or you can buy the "kit" from ems for about a grand.
Old March 25th, 2010, 12:48 PM   #19
PavementPounder
thanks
Nope. You can find multiple threads about it on Pirate. I'm not typing it all when it is already out there.
Pirate is also blocked at work, so I can't link or copy/paste even if I wanted to.
Old March 25th, 2010, 12:55 PM   #20
95ram
i have a 00. will this make a difference or will i need the same parts as you listed for the swap?
PP, ill jump over there and check it out
thanks for all the responses
Page generated in 0.44554 seconds with 83 queries
