dana 60 front spindle obsolete??? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 24th, 2010, 03:42 PM   #1
joe_jeep
welfare wheeler
joe_jeep's Avatar
Default dana 60 front spindle obsolete???
i went to dts today and took my spindle with me(its smoked). i show the guy what i need. he looks in a few books. goes in the back. comes back tells me its obsolete?? it should be dana part number 700022 from my online digging.
i see it for sale online. im assuming hes just mistaken??
anyone had trouble sourcing a d60 spindle??
i looked at bronco graveyard they list one for 78 & 79, the same one is listed for 85 to 91. i dont see one listed in between those years.
mine is kingpin, but i dont think its 78/79 vintage, and 85 to 91 i thought was ball joint.
are there any differences in spindles(pre superduty era)?
thx
Old March 24th, 2010, 04:42 PM   #2
Tab
Tab's Avatar
85-91 is still kingpin so they should be the same. I wouls order one off the internets if your local guy is that retarded.
Old March 24th, 2010, 05:22 PM   #3
joe_jeep
welfare wheeler
joe_jeep's Avatar
i would have thought they were the same too??
i hate to order online and get the wrong one and be screwed.
ill call bronco graveyard and see what they think too.
usually dts is pretty good?? i guess i got the wrong counter guy.
Old March 24th, 2010, 06:13 PM   #4
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Ford used TTB between those years. And as Tab said, the '85-91 is kingpin. This is pretty well established stuff.
Old March 24th, 2010, 07:12 PM   #5
joe_jeep
welfare wheeler
joe_jeep's Avatar
im talking about dana 60's. ive never heard of a ttb dana 60.
ttb is dana 50 and 44 im pretty sure.
the spindles appear to be all the same from 78 to 92 from what i can see.
i ordered one from bronco graveyard. price was pretty good. it is part number 700022 or 700022x.
Old March 24th, 2010, 07:44 PM   #6
bigblockford79
Big Block Ranger
bigblockford79's Avatar
The 3/4 ton Dana 50 TTB uses Dana 60 parts knuckles out.
Old March 24th, 2010, 07:45 PM   #7
bigblockford79
Big Block Ranger
Here you go, don't appear to be out of stock.
http://broncograveyard.com/bronco/i-...0-spindle.html
Old March 24th, 2010, 07:47 PM   #8
TTB D50 spindles are slightly different then D60 spindles. They "can" work in place of the 60 spindle but they do not protrude as far into the knuckle.
And the older 3/4 ton TTB's were HD D44's not D50's.
Old March 24th, 2010, 08:20 PM   #9
bigblockford79
Big Block Ranger
http://completeoffroad.com/i-123138-...e-700022x.html
Old March 25th, 2010, 08:07 AM   #10
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
Did you get Gordo?
He's an idiot. I ordered an aAburn for an AMC 20 and he transposed the numbers and I got one for a 10-bolt. He was supposed to get it picked up, but here it sits (no big deal, someone with a 10-bolt will want it).
Old March 25th, 2010, 10:26 AM   #11
liv2mx
i like jungle gym's.
liv2mx's Avatar
i used the spindle off a balljoint 60 on my 79.the same thing but the newer one has a lock pin between the 2 nuts, so it will keep the outer nut locked..a better setup then the older style.
Old March 25th, 2010, 10:37 AM   #12
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
You said nuts...
Old March 25th, 2010, 10:51 AM   #13
liv2mx
liv2mx's Avatar
Originally Posted by BigBlockBlazer View Post
You said nuts...
you got a stiffie now..
Old March 25th, 2010, 01:18 PM   #14
busyfixin
Balls Deep
busyfixin's Avatar
i think the part that protrudes into the knuckle is also a smaller diameter. and like you said not as deep.
Page generated in 0.27496 seconds with 65 queries
