2000 chevy s10 blazer 4x4 2dr questions - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 25th, 2010, 02:50 PM   #21
beedle4
beedle4's Avatar
It is not a LSD it is a mechanical locker. It is a huge POS but it is a "real" locker. But when it does work it works as a LSD for the most part.
There is video on you tube of how it works.
Old March 25th, 2010, 02:58 PM   #22
wheelinblazer98
wheelinblazer98's Avatar
are you sure about that?
maybe the ZR2s came with lockers, but im 90% sure that mine is a LSD. ill do some more searching. i could be wrong.
wheelinblazer98 is offline   Reply With Quote
Old March 25th, 2010, 03:23 PM   #23
wheelinblazer98
idk, im getting conflicting info with google searches, im still almost positive that mine and all of the others are LSDs though. either way you are correct that its a big POS.
i believe that GM just uses the G80 as a code that there is a diff traction devise in the vehicle and then depending on what vehicle it is it gets a locker or a LSD. it seems that every RWD vehicle that has a LSD or a locker has the G80 code.
Old March 25th, 2010, 08:35 PM   #24
JoshuaCripe
JoshuaCripe's Avatar
fine does have the huge fender flares....john said the zr2 has a factory 4 inch lift over a stock blazer and i know mine doesnt have a 4 inch lift.....its like a zr2 without being a zr2..lol
JoshuaCripe is offline   Reply With Quote
Old March 26th, 2010, 12:12 AM   #25
beedle4
beedle4's Avatar
All s-series lockers are the same G80, just like in the full size.
It not a 4" lift its about a 2" then another inch from the tires.
Its not like you look under and see a lift, its built into the frame mounts and shit.
Sounds like it is a Z, please post some pics to comfirm.
Old January 23rd, 2011, 02:30 PM   #26
88Chev
88Chev's Avatar
Send a message via MSN to 88Chev Send a message via Skype™ to 88Chev
Originally Posted by beaterk5 View Post
im running 31's with just the t.b. turned up about an 1" on my 2dr jimmy with a little rub at lock on frame/sway bar i havent had them rub other than that
That's like with myself. I have a 1988 S10 p/u 4x4, put 3 1/4" keys on her and cranked them completely, running 3" lift up front with 3" shackles in the rear and running 33x12.50's and only have a little bit of rub on the cab, but only cause I'm too lazy to cut a hole IN The cab and weld in a plate of sheet metal to compensate the hole in the floor. But I've never had them rub on my Swaybar, or on the frame. In fact I can put 35's on her and they still won't rub the frame cause I got
15x10 rims, with 2" backspacing, so it kicks them out from under the truck. Got the rims for only 49.00 a piece through Summit Racing. ;)
88Chev is offline   Reply With Quote
Old January 24th, 2011, 11:22 AM   #27
beaterk5
beaterk5's Avatar
Send a message via MSN to beaterk5
mine was a 99 on stock wheels
beaterk5 is offline   Reply With Quote
Old January 24th, 2011, 12:36 PM   #28
GerkTJ
GerkTJ's Avatar
I have a 2000 ZR2 that i will be parting out next weekend if you need any parts!! Motor, gas tank, and front seats are spoken for.
GerkTJ is offline   Reply With Quote
Old January 24th, 2011, 01:30 PM   #29
bigdogwaggy
bigdogwaggy's Avatar
pics? wondering if it has some bushwackers on an otherwise stock truck allowing for bigger meats..
bigdogwaggy is offline   Reply With Quote
Old January 24th, 2011, 01:54 PM   #30
bdd1469
bdd
bdd1469's Avatar
S 10 s jimmys bravadas All use the eaton gov lock as an optional locker.when there new with stock tires there ok, after that there a pos. All s series come with a 7.5 or 7.625 rear axle unless its a zr2, then its a 8.5 with the same pos gov lock design. Pretty capable stock but the frames are real low to the ground and ifs doesnt like to be lifted.they eat ball joints!put moogs in and grease often!other then that there a good dd.
Page generated in 0.20509 seconds with 53 queries
