breather tube for dodge trans - Great Lakes 4x4. The largest offroad forum in the Midwest
Old July 28th, 2006, 07:30 PM   #1
Chop
Mischievous Badger
Chop's Avatar
Default breather tube for dodge trans
heres a nice little bit of info i found for you dodge guys
http://www.pavementsucks.com/forums/...hp?topic=49209
Old August 4th, 2006, 12:38 AM   #2
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
If you see where his breather is at it is behind where the band goes. This allows the oil to be slung at the breather while it is running. I locate mine over the band this way it is sheilded. I have been doing this to dodge trannies for many, many years.
Old August 4th, 2006, 07:29 AM   #3
84Scrambler
That is exactly how I did the breather on my 46re. 90* fitting and a hose thru the bell housing up into the engine compartment.
Old August 4th, 2006, 09:41 AM   #4
KILLER"B"468
Yankabilly
I have done it that way in the past, but I like it on the outside of the case. You can get better fittings with better orifices for venting.
Page generated in 0.12956 seconds with 35 queries
