dana 44/60 4:88/5:13 Detroit lockers - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2010, 04:13 PM   #1
spiderman32
GETTING THERE
spiderman32's Avatar
Default dana 44/60 4:88/5:13 Detroit lockers
Ok so i have some decisons to make. I want to go with 4:88 gear with detroit lockers. I see some gears that are regular and some that say Reverse whats up with that??? I do want to go with lockers, but don't know if there are different lockers that will do, for a little less in price. I don't want to be cheap but i don't want to get raked over the coals for it. I saw some G2 R&P. It looks like each axle will run me about $1000 to do. I know this is alot of info, but i need to know this shit. What other brackets will i need to do a SOA. i have a 95yj/5" lift/35" tires. plz help thanks
spiderman32 is offline   Reply With Quote
Old March 22nd, 2010, 04:24 PM   #2
thrca
UberGeek
thrca's Avatar
Reverse gears are for high pinion diffs.
thrca is offline   Reply With Quote
Old March 22nd, 2010, 04:34 PM   #3
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
yep...the reverse cut gears are for hi pinion axles.
As for lockers.....I would get the detroits........Most of the cheaper stuff (lockright, aussie, ect) just replace the spider gears and reuse the stock carrier.......alot of people use them with great success.......my experience with a lockright down right sucked......I now have a detroit.
Old March 23rd, 2010, 11:52 AM   #4
spiderman32
GETTING THERE
Default bump
bump
Old March 23rd, 2010, 11:54 AM   #5
thrca
UberGeek
thrca's Avatar
Which question are you still pending on?
Old March 23rd, 2010, 02:16 PM   #6
spiderman32
GETTING THERE
Default soa
I saw some G2 R&P. It looks like each axle will run me about $1000 to do. What other brackets will i need to do a SOA. i have a 95yj/5" lift/35" tires. plz help thanks
Old March 23rd, 2010, 02:52 PM   #7
Mulely
Mulely's Avatar
Send a message via AIM to Mulely
Google is your friend.
Mulely is offline   Reply With Quote
Old March 23rd, 2010, 03:30 PM   #8
PavementPounder
PavementPounder's Avatar
Originally Posted by spiderman32 View Post
bump
Were you even off the 1st page?
Old March 23rd, 2010, 04:48 PM   #9
974x4Taco
Flex Is OverRated
974x4Taco's Avatar
g2 is just a brand of gears (yukon, precision, motive are some others)
1000 per axle is probly about right for parts (gears, detroit, master install kit).....labor will be more.......and I don't know what size tires you are gonna run but if they are gonna be bigger than your current 35's you might as well figure on chromo shafts and high strength u-joints for the 44.
what other brackets do you need??? well what do you have?
I am by no means a jeep guy......but off the top of my head you for sure are gonna need to move the spring perches, most likely the shock mounts, and some other things.
Do the yj's still have the shackle in the front?? if so I would move it to the rear.
i think there are some company's out there (blue torch fab maybe?) that make some pretty nice and comprehensive kits to put full width sprung over axles in theses rigs........given the amount of questions here and your apparent lack of willingness to search on your own I would probly suggest you buy the kit since all the R+D has already been done and you can just weld it all together.
Old March 23rd, 2010, 10:42 PM   #10
spiderman32
GETTING THERE
i have been doing as much research as possible!!! i just want make sure i'm getting the right stuff. I want to also make sure i'm not wasting my money either.
Page generated in 0.19948 seconds with 53 queries
