Control Arm Bushing Help - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 22nd, 2010, 01:39 PM   #1
steelhd1
Hypnotized
steelhd1's Avatar
Question Control Arm Bushing Help
I bought some short adjustable arms of a board member and installed them. Afterwords there was some loud pop's and clanks so I pulled the upper and lower front off. The metal sleeve is bigger that the 3/8" factory bolts, and the arms call for the factory hardware.
To make things short, I bought some Moog bushings to replace the ones in there. The problem is I can't press the new one with the metal sleeves into the arms. Only had a 2 ton H press for the job.
Can anyone help me out getting the new bushings pressed in? Also, what are the ramifications of taking all arms out to have this done? Any other advise is appreciated!
TIA
steelhd1 is offline   Reply With Quote
Old March 22nd, 2010, 01:42 PM   #2
jeepnxj96
jeepnxj96's Avatar
uuuhhhh factory moog bushings probably will not fit in any aftermarket arms.
Old March 22nd, 2010, 01:43 PM   #3
ajmorell
Find out what size bolt you need and drill out the holes in your brackets to match the sleeve diameter
Old March 22nd, 2010, 01:44 PM   #4
steelhd1
Hypnotized
steelhd1's Avatar
The arms call for factory sized bushings and look the same.
Old March 22nd, 2010, 01:46 PM   #5
steelhd1
Hypnotized
steelhd1's Avatar
Was considering this but wanted to replace the bushings with new ones since I already have them. And retain the stock bolt size for when the are replaced again.
Old March 22nd, 2010, 01:55 PM   #6
jeepnxj96
jeepnxj96's Avatar
ahhhh I see, usually all you need is an impact and ball joint press. while pressing the bushing in try tapping on the bushing housing, much in the same way you would do when doing ball joints or u-joints, helps release tension caused by pressing them in or out
Old March 22nd, 2010, 01:57 PM   #7
steelhd1
Hypnotized
steelhd1's Avatar
Will give a try. Do you think the press will be good enough, or should I look for a more qualified candidate?
Old March 22nd, 2010, 02:00 PM   #8
jeepnxj96
jeepnxj96's Avatar
should work fine....you pressed them out with it right???? measure the ID of the arm and the OD of the bushing, I have had moog ball joints come out of the box with ~.005 interferance with out the knurling for deformation.......obviosly will not work well. just a thought, not sure if moog is still made in the U.S. or not
Old March 22nd, 2010, 02:03 PM   #9
Bc1980
My press bushing experiences
I have used dawn dishsoap,and a ball joint press/shop press.
Ive on ocasion had to slightly bevel bushing edge with a grinder and then press in.
Bc1980 is offline   Reply With Quote
Old March 22nd, 2010, 02:05 PM   #10
steelhd1
Hypnotized
steelhd1's Avatar
I had to pound the SOB's out along the slight flange to get then out (pia). They went in fine before hitting the little ridge at the top of the bushing. I looked at the oem's and they had the same type ridge?
I will have to measure both as suggested...
Old March 22nd, 2010, 02:09 PM   #11
jeepnxj96
jeepnxj96's Avatar
if you weren't so far away I would say bring the over and I would install the for ya, but you probably don't want to make that trip LOL
Old March 22nd, 2010, 02:12 PM   #12
steelhd1
Hypnotized
steelhd1's Avatar
Haha Thanks for the offer but it is quite a drive. I will figure it out somehow
Old March 22nd, 2010, 02:31 PM   #13
fsumotorhead
N8KVB
fsumotorhead's Avatar
get a cooler full of dry ice and let the bushings cold soak over night, they will damn near fall in
i usually get dry ice from meijer
Old March 22nd, 2010, 02:33 PM   #14
steelhd1
Hypnotized
steelhd1's Avatar
That was another thought, thanks for the help!
Page generated in 0.37576 seconds with 65 queries
