D30 Axle swap - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 20th, 2010, 09:32 PM   #21
thrca
UberGeek
thrca's Avatar
a nice sized cheater. The crush sleeve requires about 400 ft lbs to crush.
thrca is offline   Reply With Quote
Old March 20th, 2010, 09:33 PM   #22
kickstand
circling the drain
kickstand's Avatar
Originally Posted by lastmanstandin View Post
Cool deal!
Well I'm getting the gears and master install kit. Is there any special tools I am going to need?
Yes.
Old March 20th, 2010, 09:35 PM   #23
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
HP D30 uses preload shims, LP uses crush sleeve.
Jesse-James is offline   Reply With Quote
Old March 20th, 2010, 10:04 PM   #24
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Originally Posted by Jesse-James View Post
Dial indicator & magnetic base.
I have access ta a dial indicator but no magnetic base...
lastmanstandin is offline   Reply With Quote
Old March 20th, 2010, 10:06 PM   #25
lastmanstandin
EvL 1
Got that covered...
Yes.
Thanks....
Are the preload shims easier to work with then the crush sleeve?
Old March 21st, 2010, 04:28 PM   #26
lastmanstandin
EvL 1
Well got my gears and master install kit, gonna read the directions and see if I can do this...
Old March 22nd, 2010, 12:54 PM   #27
lastmanstandin
EvL 1
What can I use for gear marking compound?
Old March 22nd, 2010, 01:17 PM   #28
thrca
UberGeek
thrca's Avatar
I'm not going to try and talk you out of anything, but I have been working on my own stuff for many years, and gears are the one thing I always take to a shop because its very difficult to do them right, and quite costly if you do them wrong.
Old March 22nd, 2010, 01:49 PM   #29
lastmanstandin
EvL 1
I hear ya. But I don't have much into this so if I fukc it up it really won't be that costly. I'm going to take my time and not rush anything. The yukon directions say a novice can do it...
Old March 22nd, 2010, 01:54 PM   #30
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
A "master install kit" should have gear marking compound.
Old March 22nd, 2010, 01:55 PM   #31
lastmanstandin
EvL 1
Yea I just went out and opened it up and it does, also has a paint brush and a bunch of other shit.
Old March 22nd, 2010, 05:41 PM   #32
lastmanstandin
EvL 1
Well this might be a little more complicated then I thought....But I'll figure it out. The booklet tells me what needs to be done but not how to do it. Does this axle have shims or a crush sleeve? I can't find shims anywhere.
Old March 22nd, 2010, 06:32 PM   #33
thrca
UberGeek
thrca's Avatar
Shims
Old March 22nd, 2010, 07:14 PM   #34
lastmanstandin
EvL 1
Ya I figured out what the shims are after a couple hours of looking on line. I wish I could find a step by step tutorial, that would make it alot easier.
Old March 22nd, 2010, 10:06 PM   #35
thrca
UberGeek
thrca's Avatar
I looked at the yukon installation guide and its pretty much step by step. Like most things involving gears, it assumes you kinda know what you are doing. (Same with locker installation guides)
Old March 22nd, 2010, 10:06 PM   #36
lastmanstandin
EvL 1
How do I meassure pinion depth? From what I understand you get your depth from meassuring from centerline of the ring gear to pinion face. What I want to know is how do I do this without the ring gear in there?
Old March 22nd, 2010, 10:10 PM   #37
MiNi Beast
MiNi Beast's Avatar
rough idea here
http://www.superchevy.com/technical/...ten/index.html
Old March 22nd, 2010, 10:18 PM   #38
HVYRTFT
Reed my teef
HVYRTFT's Avatar
judging by your past posts, I am guessing you don't have the experience to install gears CORRECTLY. And If you do fukc it up, it actually will be costly. It may not explode the month or so after you 'install' them, but it eventually will.
Old March 22nd, 2010, 10:20 PM   #39
thrca
UberGeek
thrca's Avatar
Which means new gears, new carrier, new bearings, possibly new axle shafts, possible new differential, and depending what speed you are going, if it locks up completely, possibly new transfer case and transmission. But yet, thats not much into it.
Old March 22nd, 2010, 10:40 PM   #40
lastmanstandin
EvL 1
I believe I can install them correctly if I can get the information I need and take my time and do it right. Everyone has to learn sometime and I have alot of faith in myself. If I could get answers to my questions I could have it done by tomarrow....
To be honest with you it really doesn't matter if the whole jeep blew up, I have less then a thosand into it Not that I would want that to happen.
I understand that this is a job that requires alot of knowledge but it's by no means hard.........
Page generated in 0.44823 seconds with 83 queries
