D30 Axle swap - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2010, 11:10 PM   #1
lastmanstandin
EvL 1
lastmanstandin's Avatar
Send a message via Yahoo to lastmanstandin
Default D30 Axle swap
Well I bought a hp D30 tonight to swap out my lp D30. My probleb is that I have to pull the 4.56 gears out of the lp to put in the HP, is this going to be a hard job? I plan on putting all new seals in it, is there antything else I should do to it while I'm at it? Thanks for the help.
lastmanstandin is offline   Reply With Quote
Old March 17th, 2010, 11:33 PM   #2
MiNi Beast
MiNi Beast's Avatar
sorry about your bad luck but you cannot use LP gear in a HP axle.
Old March 17th, 2010, 11:43 PM   #3
kkodet
kkodet's Avatar
You will need to buy new gears, as mini beast said, they won't work.
Old March 17th, 2010, 11:49 PM   #4
MiNi Beast
MiNi Beast's Avatar
my girl even knew that
call me man before you start buying shit man.
Old March 17th, 2010, 11:50 PM   #5
lastmanstandin
EvL 1
Ok well no big deal I guess. I didn't know when I bought it so i kinda planed on it anyways.
Old March 17th, 2010, 11:52 PM   #6
MiNi Beast
MiNi Beast's Avatar
tell me why you are swapping anyways, not like you really need it, best spend money on something else man.
Old March 18th, 2010, 12:00 AM   #7
thrca
UberGeek
thrca's Avatar
besides, lp30 to hp30 is not enough of an upgrade to warrant all the money to regear it and what not..
thrca is offline   Reply With Quote
Old March 18th, 2010, 12:03 AM   #8
lastmanstandin
EvL 1
Because I got a great deal on it and it's stronger then what I have. Also the one on the tj right now has a beat up bent LCA bracket.
Plus the yoke on the one I have bounces all around because something is warn out in it.
I also picked up another lp d30 so I'll probley put that in there for now untill I can get some gears for the hp axle...
I might not need it now but the way I'm wheeling it won't be long before I do.
Old March 18th, 2010, 12:13 AM   #9
thrca
UberGeek
thrca's Avatar
Its your money... I was just saying, instead of replacing it 2 or 3 times, you could upgrade one time and end up spending less.
Old March 18th, 2010, 08:11 AM   #10
kkodet
kkodet's Avatar
What did you get the HP 30 out of? If it's not a 297 u-joint unit from a 94-99 XJ, it's not stronger than what you already have.
Old March 18th, 2010, 08:13 AM   #11
Jeepaholic
Axle Guru Extraordinaire
Jeepaholic's Avatar
If nothing else it help get the driveshaft out of the rocks, and it is stronger. If the lp needs work it won't cost much more to get the hp set up. Keep your eye out on the jeep boards for a used set of 4.56's
Old March 18th, 2010, 08:13 AM   #12
Jeepaholic
Jeepaholic's Avatar
But the tj shaft fit in the hp, worse case it cost a seal and a scrap piece of plate.
Old March 18th, 2010, 01:02 PM   #13
lastmanstandin
EvL 1
I think I'm going to put new seals in the lp and use that untill I can get 4.56 gears for the HP D30.
Old March 20th, 2010, 07:35 PM   #14
lastmanstandin
EvL 1
Ok so I now have 4.56 gears coming for this hp D30. I opened it up and from what I can tell it has 3.55 gears in it. What I need to know is do I need to buy any more parts like a different carrier or will the gears work with what I have. Thanks.
Old March 20th, 2010, 07:43 PM   #15
96 s10 blazer
96 s10 blazer's Avatar
thought you all ready had a carrier with 4.56 gears just needed the gears for a high pinion just swap the gears but use the low pinion carrier...others correct me if I am wrong
96 s10 blazer is offline   Reply With Quote
Old March 20th, 2010, 07:47 PM   #16
lastmanstandin
EvL 1
That would be great if that will work.....
Old March 20th, 2010, 07:54 PM   #17
thrca
UberGeek
thrca's Avatar
There should be no difference in the carrier between the two, just the gears and pinion, IIRC.
Old March 20th, 2010, 08:10 PM   #18
ajmorell
same carriers
Old March 20th, 2010, 08:14 PM   #19
lastmanstandin
EvL 1
Originally Posted by ajmorell View Post
same carriers
Cool deal!
Well I'm getting the gears and master install kit. Is there any special tools I am going to need?
Old March 20th, 2010, 08:30 PM   #20
Jesse-James
Midwest Mudslinger
Jesse-James's Avatar
Dial indicator & magnetic base.
Jesse-James is offline   Reply With Quote
Page generated in 0.43548 seconds with 83 queries
