Temp gauge question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2010, 08:45 PM   #1
cmays03
BUILD BY ME NOT BOUGHT!
Default Temp gauge question
Ok I want to put a trans temp gauge in my off road rig and was wondering if a normal temp gauge will work or if you have to get the trans temp gauge one? The normal trans temp gauge is 1/3 the price of the trans temp and really dont want to spend that much if i dont have too. thanks
cmays03 is offline   Reply With Quote
Old March 17th, 2010, 08:49 PM   #2
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
the only difference i know of is that temp gauges usually stop at 260. trans gauges go to 300.
Kodiak450r is online now   Reply With Quote
Old March 17th, 2010, 09:03 PM   #3
cmays03
yeah but the trans shouldnt get that hot anyways thou right. mine dd never gets over 170 and thats with hauling heavy loads
Old March 17th, 2010, 09:36 PM   #4
jbsjunk
Little Member
jbsjunk's Avatar
With all the Auto-meter gauges I've done, the only difference I've seen is the gauge face. It's the same sender for water, trans, etc and the temp gauges have the same temp range, at least the ones I've used. There are obviously electric. Mechanical still wouldn't be a problem other than where to plumb the probe. You can get a block that would go inline with your trans cooler lines. Or you can weld a bung in the pan.
Old March 17th, 2010, 10:24 PM   #5
cmays03
well i have a aftermarket trans cooler so i was going to make a block and run the lines thru that and then the sender to it also. just wanted to make sure before i went and bought another temp gauge and it didnt work and then have to go buy the trans one. Thanks guess i will make that block tomorrow and get that installed. I'll post on there once i get everything done and cant test it out. that should be awhile since i dont have the motor or anything in it yet and still have to build my motor. thanks for the info thou.
Old March 18th, 2010, 09:27 AM   #6
phittie1100
phittie1100's Avatar
Not sure how much cheaper a water temp gauge is, but I just picked up a kit at NAPA - wiring, t-connection for the sender and gauge for $55 or so, universal fit.
Paul - 2005 Wrangler Unlimited
KD8PAV
phittie1100 is offline   Reply With Quote
Old March 19th, 2010, 12:34 PM   #7
fsumotorhead
N8KVB
fsumotorhead's Avatar
for the most accurate info, you trans temp gauge sender should be located in the pan
Old March 19th, 2010, 01:46 PM   #8
SHARPMACHINE
F-U-CANCER!!!
SHARPMACHINE's Avatar
I have always scene/thought it should be in the "hot" line coming from the tranny.
RIP FULLSIZE4LIFE
Old March 19th, 2010, 05:46 PM   #9
jbsjunk
Little Member
jbsjunk's Avatar
For all of the electric gauges I've done, I've used one of the test ports on the trans. Unscrew the plug and screw the sender in. They make a short sender for limited depth applications.
Page generated in 0.33251 seconds with 50 queries
