12 bolt carrier question - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 17th, 2010, 08:00 AM   #1
chevyman123
chevyman123's Avatar
Default 12 bolt carrier question
i just bought a 12 bolt rear end for my 84 chevy im not sure what the gears are can i use the carrier in the rear end and put a 4 11 on it?
chevyman123 is offline   Reply With Quote
Old March 17th, 2010, 01:12 PM   #2
PavementPounder
PavementPounder's Avatar
Differential Case Breaks (or, "Do I need a new carrier?") - Great Lakes 4x4. The largest offroad forum in the Midwest
Notice that the sticky I linked is located in the Axle Tech forum.
Old March 17th, 2010, 02:37 PM   #3
chevyman123
what im confused on is a couple people told me that the rear end that i got is a series three carrier so i would need a ring spacer i was just wondering if it was true
Old March 23rd, 2010, 12:38 AM   #4
Ebrown
Ebrown's Avatar
I've never heard of anything like that.. My book only shows 1 Carrier and that 3.73 and up! There are 2 different types of Corp 12 bolt axles ( Car and Truck)( Car came in 5 lug and the truck axle came 5 & 6 lug also) There are different dif covers also and there not interechangable! Are you sure there were looking at the correct axle?
(I'm not sure if this applys ro not)?
More and likely you are going from a thick ring gear to a thin one, if this is so you might want to look around for the thick ring gear as it would be stronger! Do you know if you have the thick or the thin ring gear on the current setup as it sits (pic help) Have you call Randy's or DTS ? There might be stamped number / letters on the edge of ring gear that will help decoding the axle more
Ebrown is offline   Reply With Quote
Old March 23rd, 2010, 09:37 AM   #5
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
There are actually three different carriers covering 2.54-6.00 gear ratios (5.38 for truck axles).
A thick gear is not any stronger than a thin gear.
It came with a 3-series carrier from the factory, unless it has 4.11 gears.
You can get a thick gear to fit the 3-series carrier, or use a standard gear with a 4-series carrier. I would NOT recommend using a ring gear spacer.
Old March 23rd, 2010, 04:19 PM   #6
Disturban
Disturban's Avatar
Originally Posted by Ebrown View Post
There are 2 different types of Corp 12 bolt axles ( Car and Truck)( Car came in 5 and 6 lug and the truck axle came 5 & 6 lug also)
I have never seen a car with a 6 lug 12 bolt rear end
Old March 23rd, 2010, 04:42 PM   #7
wheelinblazer98
wheelinblazer98's Avatar
with a title like "rear ends" i was hoping for more NSFW. haha
wheelinblazer98 is offline   Reply With Quote
Old March 24th, 2010, 01:14 PM   #8
Ebrown
Ebrown's Avatar
Ya I should have looked alittle harder! GM Car 12 Bolt rear axle 68-72 Chevelle & El Camino, 70-72 Camero
Link to 12 bolt car axle:
http://www.supercarsunlimited.com/in...id/diff_id.htm
Hot rod tech
http://www.hotrod.com/techarticles/d...all/index.html
Old March 24th, 2010, 01:24 PM   #9
Jeeperz Creeperz
GL 4x4 Vendors
That link is for a BPO axle, not the 8.875" 12-bolt, and is totally different than the axle being discussed in the thread.
Old March 25th, 2010, 02:07 PM   #10
Ebrown
Ebrown's Avatar
Just replying to this! After rereading my post I mis typed " Should have been 5 lug not 6. How ever I made corrections
YC G6258086 12T 3.73 Standard open case fits 3.73 and up to 5.57 and use 6Gmt-411 (thin Gear) Ring and pinion (you will not have to use a spacer) you would also have to order the spide gears kit also.. Call there tech support 800-292-1031
Call Randys Ring and Pinion
http://www.ringpinion.com/DiffDetails.aspx?DiffID=34&PartsLink=PartCats.aspx %3fSearchMode%3dDiff%26TypeID%3d5%26DiffID%3d34
http://www.ringpinion.com/DiffDetail...%26DiffID%3d33
Old March 25th, 2010, 07:22 PM   #11
Cooter
Dad Kickin' It OldSkool
Cooter's Avatar
Thread moved, title changed,and honestly, I should have just binned it.
Page generated in 0.22760 seconds with 57 queries
