D30 (possibly bad) and Ford 8.8 4.10 gears - SOLD - $425 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 16th, 2010, 08:20 PM   #1
Strider
Strider's Avatar
Send a message via Skype™ to Strider
Default D30 (possibly bad) and Ford 8.8 4.10 gears - SOLD - $425
Sold, thanks for looking.
No longer just a feeler - I am going to upgrade my front axle from the D30 to a D44 and since the D44 has the 5 on 5.5 bolt pattern I am considering switching from the Ford 8.8 to a Ford 9".
The front axle needs at least a pinion bearing. It started a couple of weeks ago with in/out slop, but now have an 1/8" of axial play as well so I don't know if this is just a stage of the bearing getting worse or what.
Both axles have 4.10 gears, the rear has factory limited slip. Both have disc brakes, the 8.8 has all of the parking brake stuff except for the cable. They are both still bolted under my 1997 TJ.
I'd like to get $450 for the pair but don't know how much interest they'll pull. the 8.8 has the D35 brackets welded on, not aftermarket brackets. They held up just fine for one year of 4.0 use, and a couple months of 5.3 use so I'd never consider changing them but at least you know ahead of time what I'm offering.
I can have these pulled in a few hours, but it can't be until early next week unless you're in a real hurry to get them. Then I'll have to borrow a car for a while which can happen if need be.
Strider is offline
Old March 16th, 2010, 08:37 PM   #2
powerranger33
powerranger33's Avatar
would you be willing to seperate the axles? and if so what would you want for the 8.8?
powerranger33 is offline
Old March 16th, 2010, 09:33 PM   #3
Strider
Strider's Avatar
I'll separate, but I want $400 for the rear. The front needs work so it has minimal value.
I need to justify the swap to a 9".
Strider is offline
Old March 17th, 2010, 11:59 AM   #4
Zatzke
Who Needs Luck?
Zatzke's Avatar
well if the gears aren't shot from the slop in the pinion I may be interested in the front axle...
Zatzke is offline
Old March 18th, 2010, 08:10 AM   #5
Strider
Strider's Avatar
I'll let you know early next week. I hope to be picking up my new axles today.
Strider is offline
Old March 18th, 2010, 03:28 PM   #6
Strider
Strider's Avatar
I have my new D44/Ford 9" now and I want money for re-gearing. Any takers?
Strider is offline
Old March 18th, 2010, 07:02 PM   #7
cloud9tj
cloud9tj's Avatar
Default axles
im intrested where can i take a look at them
cloud9tj is offline
Old March 18th, 2010, 07:43 PM   #8
Strider
Strider's Avatar
Holland, MI. They're under my Jeep still, but will hopefully be replaced next week.
Strider is offline
Old March 19th, 2010, 08:58 AM   #9
Strider
Strider's Avatar
I removed "FEELER" and these are definitely for sale or trade. I'm looking for 4.10, 4.56, or even 4.88 gears for a D44HP (reverse cut) and a Ford 9", also lockers for both axles. I'd think about a winch, but it would have to be a Warn, 8274 would garner extra interest.
Strider is offline
Old March 19th, 2010, 12:58 PM   #10
Zatzke
Who Needs Luck?
Zatzke's Avatar
How much for just the front axle? All I'm really interested in is the gears and axle shafts if somebody needed the rest...
Zatzke is offline
Old March 19th, 2010, 04:11 PM   #11
Strider
Strider's Avatar
$50 for the Front Axle alone sound fair?
Strider is offline
Old March 19th, 2010, 04:38 PM   #12
Zatzke
Who Needs Luck?
Zatzke's Avatar
sounds pretty fair, any idea if the gears are still good?
Zatzke is offline
Old March 19th, 2010, 04:48 PM   #13
Strider
Strider's Avatar
I really don't. My guess is YES, but I won't even have time to pull the cover until next week when I get my dad's Jeep out of my garage.
Strider is offline
Old March 20th, 2010, 07:59 AM   #14
Strider
Strider's Avatar
I'm sorry, but there is one more thing. The front axle housing was modified to work with radius arms. The stock passenger side upper control arm bracket was removed and replaced with shorter brackets from Lane Automotive. This was actually done so the radius arms would clear the AC pump on the 5.3l V8.
Strider is offline
Old March 20th, 2010, 12:54 PM   #15
Zatzke
Who Needs Luck?
Zatzke's Avatar
not a problem for me, like I said I'm only interested in gears and spare axle shafts... let me know the shape of the gears and I can probably come take it off your hands sometime soon!
Zatzke is offline
Old March 21st, 2010, 08:45 AM   #16
powerranger33
what do you want for the 8.8?
Old March 21st, 2010, 02:18 PM   #17
Strider
Strider's Avatar
$400 for just the 8.8, $50 for the D30.
Strider is offline
Old March 25th, 2010, 05:19 PM   #18
Strider
Strider's Avatar
Ttt
Strider is offline
Old March 27th, 2010, 04:26 PM   #19
Strider
Strider's Avatar
Bump
Strider is offline
Old March 28th, 2010, 09:40 PM   #20
plowboy
4Wheel 4 Life
plowboy's Avatar
still have the axles, looking to upgrade my grand cherokee axles. Is the front a high pinion? Has the 8.8 rear got all the brackets for the arms still?
plowboy is offline
Page generated in 0.34269 seconds with 83 queries
