Taking great photos at a beach setting - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > Other Stuff > Photography and NON-4x4 related photos
Old March 16th, 2010, 03:14 PM   #1
TJJEEP
TJJEEP's Avatar
Send a message via AIM to TJJEEP Send a message via MSN to TJJEEP
Default Taking great photos at a beach setting
I have struggled to get the color right with beach photos with my SLR. My Cannon came with UV filters which I always kept on, but when i took them off i noticed the color was much richer in the pictures.
Here are 2 pictures taken - 1 with the UV and one without. Same lense in almost the same area on the beach. The color pops a lot more in #2 and is more true to how it was.
I just read about polarized fileters. has anyone used these?
ID:	59410   Click image for larger version
TJJEEP is offline   Reply With Quote
Old March 16th, 2010, 03:24 PM   #2
bellmer
bellmer's Avatar
ive seen pictures with polarized filters there is definately quite a difference.
bellmer is offline   Reply With Quote
Old March 16th, 2010, 04:19 PM   #3
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
Polarized filters are awesome in my opinion. If getting one you want a circular polarized filter (CPL) for a digital body, something to do with the focusing mirrors.
A note on the image differences also, you may want to look at the white balance settings for each photo. The camera body may have changed the WB setting which would cause different colors completely.
Old March 16th, 2010, 04:48 PM   #4
TJJEEP
TJJEEP's Avatar
Thanks, I believe i had the WB manually set the same setting both pictures. I usually manually set it.
Old March 19th, 2010, 10:36 PM   #5
cjric
cjric's Avatar
Looks like the angle of the sunlight more than anything. First one the sun is in front of you, or directly above, and is skimming off the water, creating reflections that are hiding the color of the water. Also, the excess light hitting the lens is decreasing your exposure time and desaturating the sky.
The second one, you have turned a little and the sun is more behind you, so you aren't getting the reflection on the waters surface, and the sun isn't hitting the lens directly.
The filter, being out in front of the lens, could also be catching some sunlight and making things worse. Think about when you shield your eyes in direct sunlight to see better.
Overly white images, like bright beaches, or snow, tend to screw up exposures because your cameras meter is programmed to expose 18% grey correctly. When you have alot of white, it tends to underexpose and turn white things muddy. Always open up a 1/2 to a whole stop when you are looking at an image that is predominately light/white.
One more reason to shoot manual.
cjric is offline   Reply With Quote
Old September 30th, 2010, 10:49 AM   #6
Dirty Turtle
Dirty Turtle's Avatar
30 seconds in lightroom and both of those could match perfectly!
Dirty Turtle is offline   Reply With Quote
Old October 6th, 2010, 01:06 PM   #7
Hacksaw
WWSD - What would stan do
Hacksaw's Avatar
That's what I was thinking.
Page generated in 2.10847 seconds with 45 queries
