Front or Rear Locker? - Great Lakes 4x4. The largest offroad forum in the Midwest
View Poll Results: Front or Rear Locker?
Front 18 66.67%
Rear 9 33.33%
Voters: 27. You may not vote on this poll
Old March 16th, 2010, 11:05 AM   #1
redhead_823
redhead_823's Avatar
Default Front or Rear Locker?
I just bought a Spartan Locker for my Scout and I'm debating whether to put it in the front or rear.
I currently have Trac-loc in the rear and open diff in front.
Since the spartan locker uses and open case, I would have to setup the gears if I put it in the rear.
If I put it in the front, then I just use the existing case and leave the gears where they are.
They are Dana 44's, if that matters.
It will see some street use, but mostly off road.
What do you think I should do?
redhead_823 is offline   Reply With Quote
Old March 16th, 2010, 12:53 PM   #2
PavementPounder
PavementPounder's Avatar
I'd still put it in the front even if you didn't have the LSD in the rear.
Old March 16th, 2010, 01:07 PM   #3
redhead_823
I'm thinking it would be more beneficial in the front since that is where most of the weight is.
I have locking hubs, so driving on the road isn't a problem.
Old March 18th, 2010, 06:32 AM   #4
redhead_823
Since I only got 1 response, it's going in the front. I got it all torn apart and the locker in the carrier last night.
Old March 18th, 2010, 08:40 AM   #5
PavementPounder
Originally Posted by redhead_823 View Post
Since I only got 1 response.
You got 13 responses. Check your Poll results.
Old March 18th, 2010, 09:28 AM   #6
redhead_823
Ok, front wins anyways.
Old June 27th, 2010, 08:53 PM   #7
Lousypirate
Whoop Whoop
Lousypirate's Avatar
with how much you are taking those diff covers off, you can switch between front and rear locker real fast bud ;)
Old June 27th, 2010, 09:12 PM   #8
redhead_823
Installing/uninstalling a locker s a little more involved than just pulling the cover off. Besides, I don't think it would be a good idea to attempt it while I'm stuck.
Old June 27th, 2010, 09:13 PM   #9
redhead_823
Update: Besides breaking a u-joint and axle shaft, the locker has worked great in the front. I just wish I had an open diff in the rear so it was easy to install another one.
Tags
dana 44, gears, locker, ring and pinion, scout
Page generated in 0.20860 seconds with 51 queries
