Priming a tj 4.0 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2010, 01:23 AM   #1
adam0351
adam0351's Avatar
Default Priming a tj 4.0
Hey I just put a crate 4.0 in my 2002 tj wrangler and was wondering if anyone knows how you are supposed to prime the oil pump to that before starting the engine?
adam0351 is offline   Reply With Quote
Old March 15th, 2010, 01:40 AM   #2
87mopar
Web Wheeler :(
87mopar's Avatar
pull the fuse for the fuel pump unhook the coil take plugs out and crank for 30 sec let starter cool off and repeat
87mopar is online now   Reply With Quote
Old March 15th, 2010, 01:41 AM   #3
1988JeepXj
XJ Aficianado
1988JeepXj's Avatar
Send a message via AIM to 1988JeepXj Send a message via Yahoo to 1988JeepXj Send a message via Skype™ to 1988JeepXj
Remove the teeth from the cam gear of an old distributor, and spin it with a drill. I know '02 didn't have a distributor but the block opening and pump drive should be the same.
I've heard some people say you can use a big old flat blade screwdriver with no handle in a drill, but I'm not so sure I'd be confident trying that.
1988JeepXj is offline   Reply With Quote
Old March 15th, 2010, 01:42 AM   #4
87mopar
Web Wheeler :(
87mopar's Avatar
pull the fuse for the fuel pump unhook the coil take plugs out and crank for 30 sec let starter cool off and repeat make sure oil filter is full
Old March 15th, 2010, 06:54 AM   #5
Dylan
Dylan's Avatar
Did that the first time I built my 4.0 and it was a BAD move. 1st with it completely dry, it takes a LOT of cranking and even then it will not prime. It does not rotate fast enough. 2nd is that you are turning your crank, cam, and everything else in the block over dry as you do this. Spinning without oil is a BAD move.
I would not ever do this again!
After having to rebuild it again due to bad bearings only 10k later, i took out the cam gear and used a big flat screwdriver on a drill. worked perfectly.
Old March 15th, 2010, 10:24 AM   #6
87mopar
Web Wheeler :(
87mopar's Avatar
okay that is a good bit of info cuz thats how they showed me at school to do it haha. realworld mechanic +mechanic in school= world of diference i think all school was good for was learning the names of things lol
Old March 15th, 2010, 11:20 AM   #7
adam0351
adam0351's Avatar
Default priming oil pump
I had thought about doing that with the flat blade screwdriver since it looked like i could with the cam sensor pulled but I wasn't sure if it would work thanks for the info guys.
Old March 15th, 2010, 02:01 PM   #8
ajmorell
ajmorell's Avatar
Just did my 98. Got the longest flat-blade screwdriver I could and cut the handle off and chucked it up in a drill. Worked like a charm.
Old March 15th, 2010, 02:08 PM   #9
forbyefore
forbyefore's Avatar
definitely use a drill.
forbyefore is offline   Reply With Quote
Old March 15th, 2010, 09:54 PM   #10
cjric
cjric's Avatar
did it once w/ an old dist. shaft, cut down and chucked in a drill. The second time, used a screwdriver.
Run it until you see oil flowing on top of the motor. You can even take the valve cover off and watch to make sure everything gets oiled.
cjric is offline   Reply With Quote
Old March 15th, 2010, 10:07 PM   #11
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
get a junkyard distributor for 10 bucks. press the drive gear off, stick that in the hole and spin it over with a drill. your going to need a powerful corded drill. oil pumps take ALOT of power to turn and a wimpy 12 volt cordless won't spin it fast enough for very long.
Page generated in 0.21914 seconds with 56 queries
