Tire Air Pressure Sensor and Oil Change Sensor? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2010, 08:11 PM   #1
awalters
Hired Badass
awalters's Avatar
Default Tire Air Pressure Sensor and Oil Change Sensor?
I've been driving my dad's buick park avenue, and it has every bell and whistle there is on this thing. It says that the tires have low pressure, but they are all at 35 pounds, which is what the sticker on the door says, and what the tires say. The light came on when he gave it to me in Illinois and it was VERY cold, compared to where it had been, so we thought the cold air caused the tires to lose the air and make the sensors trip.
Long story short, tires are correct, how do I tell the computer they are correct.
Also, it has an "oil life index" on the screen, and it said 51% when I got the car, it now says 31% and his sticker said it was due, so I changed the oil, but it still says 31%. How do I tell it I put new oil in?
awalters is offline   Reply With Quote
Old March 14th, 2010, 08:14 PM   #2
hondadirtracer
Skymaster
hondadirtracer's Avatar
I wouldn't yell at it. Try a nice calm voice, maybe caress the dashboard a bit before you break the news.
Does it have a reset button for the readout?
hondadirtracer is offline   Reply With Quote
Old March 14th, 2010, 08:18 PM   #3
awalters
Hired Badass
awalters's Avatar
It does, It still thinks the tires are low. I haven't tried it for the oil. Do I have to hold it down, or anything like that. All that does is clear the trip odometers.
Old March 14th, 2010, 08:22 PM   #4
Nuzzy
likes him some Red Dog
Nuzzy's Avatar
RTFM
Nuzzy is offline   Reply With Quote
Old March 14th, 2010, 08:22 PM   #5
hondadirtracer
Skymaster
I would think if you go to where it displays the oil info and hold the reset button, it should reset the life.
Old March 14th, 2010, 08:28 PM   #6
awalters
Hired Badass
awalters's Avatar
Originally Posted by Nuzzy View Post
RTFM
Old March 14th, 2010, 08:57 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
owners manual my friend. there is a reset procedure you have to follow in order for the TPM to reset. same with the oil life monitor.
Old March 14th, 2010, 08:59 PM   #8
awalters
Hired Badass
awalters's Avatar
Unfortunately, I don't have the manual. It's my dad's car. I guess I'll call him in the morning and have him look for the manual.
Old March 14th, 2010, 09:03 PM   #9
special k
special k's Avatar
depending on the year, to reset the oil change light, you will have to pump the gas pedal 3 times, and hold it for a few seconds on the third pump, and i think if it recognizes that it will flash the oil change light a few times. if it's the newer style it's with the buttons that cycle you through the trip meter, fuel mileage, and all that shit.
Old March 14th, 2010, 09:04 PM   #10
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
unfortunatly i can't remember the reset procedure i had to do on a 00 olds alero a few weeks ago. but knowing GM the procedure is different on every model.
the oil life reset is turn key to the on position stomp the gas pedal to the floor 3 times and let off. the oil light will flash then turn the key off. start the car the light will flash and go out. the next time you start it the light shouldn't come on. this is the typical procedure but varies from model to model.
Old March 14th, 2010, 09:12 PM   #11
Bishop
Bishop's Avatar
try google
Old March 15th, 2010, 01:41 PM   #12
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
You are busting my balls here!!! Send me a PM if you haven't found out how to fix your problems yet!!
Old March 15th, 2010, 04:42 PM   #13
awalters
Hired Badass
awalters's Avatar
I got it, it was a combination of buttons. Do you guys reset that kind of stuff when you do oil changes for customers?
Old March 15th, 2010, 05:30 PM   #14
Hoss Blazer
!SPARTY ON!
Yep!!
Old March 15th, 2010, 05:35 PM   #15
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
Scroll through the info settings. The GM TPMS usually have a relearn procedure. It could also be one of the sensors' batteries starting to go. What year is it?
Old March 15th, 2010, 05:39 PM   #16
awalters
Hired Badass
awalters's Avatar
a 1998.
Old March 15th, 2010, 05:45 PM   #17
GreaseMonkey
Pew pew!
a 1998.
If the sensors have never been changed before, I bet the sensors may be on their way out.
Start letting air out of one of the tires and see if it picks it up. Scroll through the info pages on the display as well. In the settings part, there may be a TPMS re-learn procedure.
Old March 16th, 2010, 05:33 PM   #18
Hoss Blazer
!SPARTY ON!
Dude they didn't use those kinda sensors back in 1998.
Old March 16th, 2010, 05:36 PM   #19
GreaseMonkey
Pew pew!
What did they use then?
Old March 16th, 2010, 07:16 PM   #20
Hoss Blazer
!SPARTY ON!
Some vehicles that currently have indirect ABS-based TPMS include 2001 to 2003 Ford Windstar, 1997-2002 Buick Park Avenue, 1999-2003 Buick Century & Regal, 2002-2003 Buick LeSabre, 2003 Buick Rendezvous & Aztek, 2000-2003 Chevy Impala & Monte Carlo, 1999-2002 Chevy Alero, 1999-2002 Pontiac Grand Am, 1997 - 2003 Pontiac Grand Prix, 2000 - 2003 Pontiac Bonneville, and 2001-2003 Oldsmobile Aurora.
Tire pressure monitor warning
As for the direct TPMS systems, they have their own technical issues as well. One is battery life. The pressure sensor inside each wheel contains a small battery to power the sensor and transponder. Most are long-life lithium batteries that may last from five to 10 years. Eventually, though, the batteries will go dead. On the Corvette and Cadillac applications, the battery can't be replaced separately so the sensor/transponder must be replaced as a unit. If a battery has died, it's probably a good idea to replace all the TPMS transponders if the vehicle is more than six years old. Some of the older Corvette systems use a piezo device inside the pressure sensor that generates current for the sensor. This eliminates the need for battery or sensor replacement.
Page generated in 0.44690 seconds with 83 queries
