4x4 Dont work - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2010, 02:12 PM   #1
dowen
Sanford MI (Midland)
Default 4x4 Dont work
changed motor and now 4x4 doesnt work any ideas Its 2.5,5speed
dowen is offline   Reply With Quote
Old March 14th, 2010, 02:15 PM   #2
JeepInABox
In too deep
JeepInABox's Avatar
more info
make year
drive shaft turn?
Vac lines hooked up to the axle?
Old March 14th, 2010, 02:57 PM   #3
kickstand
circling the drain
kickstand's Avatar
changed what motor?
Old March 14th, 2010, 02:58 PM   #4
dowen
Default 4x4
Its a 1990 yj,looks like the vac lines are hooked to the front axle dont know if the drive is turning It worked before I changed motor
Old March 14th, 2010, 03:01 PM   #5
JeepInABox
In too deep
JeepInABox's Avatar
Put it in 4wd and look under it while someone else creaps it forward.
if the front shaft turns the problem is in the axle
Old March 14th, 2010, 05:24 PM   #6
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
I am guessing you did not reconnect the vacuum line to the transfer case.
Page generated in 0.15264 seconds with 41 queries
