727 expert needed - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 14th, 2010, 06:40 AM   #1
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
Default 727 expert needed
I think I figured out whats wrong with the trans on my M880. the kid got it stuck almost vertical in the yard and finally backed out of it after it quit going forward up hill. I thought he smoked the forward pack but I proved that it worked by starting in low and up shifting to drive once its was rolling. so my question is this, if the trans is wounded and doesn't go forward in drive from a stop what do you think failed? low works in manual mode and drive works once rolling and up shifted manually. reverse works fine to.
Yetti
Old March 14th, 2010, 07:12 AM   #2
SANDVIPR
Yeeeee Haaaaw!
SANDVIPR's Avatar
I would PM Nosights.... He seems to know a ton about the old school dodge stuff. If he doesn't know, I'm sure that he'll be able to get an answer for you.
Old March 14th, 2010, 10:43 AM   #3
steelhd1
Hypnotized
steelhd1's Avatar
Paging Tranny Tom...
steelhd1 is offline   Reply With Quote
Old March 14th, 2010, 09:42 PM   #4
Tom
Because racecar
Tom's Avatar
Does it move at all In drive? Is it like it is neutral or does it feel like its bound up?
What comes to mind:
1) You still may have a forward clutch issue, and the low gear is helping you get moving. Low gear is a combination of the front and rear planetary sets, low/reverse band is applied so the low-reverse drum stays stationary to hold the rear planet carrier.
2) or a severely stuck governor, but if that is the case it would/can effect reverse.
I still think the forward (or rear clutch as it is referred to in relation to the placement inside the trans) is still the culprit.
Old March 15th, 2010, 06:07 AM   #5
Yetti
Yetti's Avatar
I was looking at my old books and I have a 904 diagram that shows the low band is not used in drive. instead it uses the one way clutch for low. so that might explain why I can launch in manual low and then jump to drive? could I have a blown one way clutch? I have seen it in Turbo 400's but never on anything else.
Yetti
Old March 16th, 2010, 09:13 PM   #6
koochman450r
koochman450r's Avatar
red barn customs knows a lot about the 727's pm him if yunto
Old March 16th, 2010, 09:27 PM   #7
Marine_mike
SNSHTF
Marine_mike's Avatar
I have a 727 from a waggy that I am sitting on right now.... not sure if it will work in your dodge... but PM me if you're looking for a replacement.
Click this link ---> http://www.gunwatcher.com/c/5751 is having a HUGE giveaway at the end of December 2014!
Marine_mike is offline   Reply With Quote
Old March 19th, 2010, 04:25 PM   #8
Yetti
Yetti's Avatar
Thanks for the info Mike. I dunno if it could work as I haven't done enough swapping of AMC vs Dodge parts? maybe someone on here might know like PP?
Yetti
Old March 19th, 2010, 05:13 PM   #9
Tom
Because racecar
Tom's Avatar
Amc and dodge cases are different. You would have to swap the guts. Depending on the years, the internals should be the same. If you are going to through all of that, you might as well rebuild yours or find a good running dodge unit.
Old March 19th, 2010, 06:38 PM   #10
Yetti
Yetti's Avatar
Thanks Tom
Yetti
Old March 19th, 2010, 09:02 PM   #11
v2win
v2win's Avatar
I wonder if some trash got loose and sucked into the valve body.
v2win is offline   Reply With Quote
Old March 20th, 2010, 06:47 AM   #12
Yetti
Yetti's Avatar
hard to say? it was whining like a bitch when it first started acting up. sounded like a dry power steering pump. it quieted down a while later after sitting. I kinda figured it had something going like a huge pile of crap shifted and blocked the screen but the fact reverse worked made me question it.
Yetti
Old March 23rd, 2010, 10:08 AM   #13
busyfixin
Balls Deep
busyfixin's Avatar
i too have been told to talk to "redbarncustoms" about 727's. cant hurt to shoot him a pm. a fellow wheeler who runs 727's may have run into it before.
Old March 23rd, 2010, 07:59 PM   #14
mudbillyredneck
mudbillyredneck's Avatar
Luke has lot's of 727's
mudbillyredneck is offline   Reply With Quote
Old March 24th, 2010, 02:15 PM   #15
rockman
might try www.steelsoldiers.com as M880s are popular there as are other MVs.
rockman is offline   Reply With Quote
Page generated in 0.25710 seconds with 68 queries
