Toyota "pedal issue" a giant hoax? - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 12th, 2010, 03:34 PM   #21
Mr.Green
I can levitate!
Mr.Green's Avatar
The throttle stuck on my Prius yesterday. I am not scared.
Old March 12th, 2010, 05:28 PM   #22
BRUSER
BRUSER's Avatar
When it all comes out you will find that a very rare set of circumstances causes a computer program failure that causes the acceleration.
The radio turned up so with the hvac on a certain setting, battery / charging system at a certain level, rear window defogger on, etc.
The combination will be obscure and difficult to pin down. That is the reason they have not identified the "true problem" and implemented a fix. The fixes in place a shots in the dark to get something in place to save face.
BRUSER is offline   Reply With Quote
Old March 12th, 2010, 05:53 PM   #23
Ebs
I :heart: technology.
Old March 12th, 2010, 06:33 PM   #24
CHEVYRCKS
Ghetto Krawler
CHEVYRCKS's Avatar
I just listen to the 911 call and that guy is a fawking retard. He is trying to scam his way out of his car payment.
CHEVYRCKS is offline   Reply With Quote
Old March 12th, 2010, 06:33 PM   #25
scottie
Eye candy
scottie's Avatar
Hoax, Morons can't drive
Old March 12th, 2010, 06:54 PM   #26
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
Only fags can't control a runaway Toyota.
Old March 12th, 2010, 08:51 PM   #27
El Jefe
El Jefe's Avatar
Originally Posted by GreaseMonkey View Post
x2.
The first guy said he smelled the brakes. If the brakes were fully applied, there is no way the engine would overpower the brakes.
Only way that could happen is if the brakes weren't fully applying all the way, and just dragging some.
er- the hybrids brake with the transmission at higher speeds mostly (to regen electric charge the battery). so it is entirely possible that the friction brakes were 'fully' applied and not able to stop the car....
El Jefe is offline   Reply With Quote
Old March 13th, 2010, 08:25 AM   #28
GreaseMonkey
Pew pew!
GreaseMonkey's Avatar
I know they are, it still just doesn't seem truthful. Even if an electric motor, like the one in the Prius, was still turning, it doesn't have the torque to overcome the brakes.
Old March 14th, 2010, 10:57 AM   #29
jeepers48
jeepers48's Avatar
Is it that hard to turn off the ignition if the throttle sticks open.
Ive had that happen with 2 different carb'd jeeps in the past.
A bear, to steer & stop without the motor running but do-a-ble.
jeepers48 is offline   Reply With Quote
Old March 14th, 2010, 11:58 AM   #30
GreaseMonkey
Pew pew!
They have push button start. You can't just shut the ignition off when it's in gear and at speed.
Old March 14th, 2010, 12:00 PM   #31
clarkstoncracker
lol
clarkstoncracker's Avatar
But do their transmissions have a NEUTRAL?
Old March 14th, 2010, 12:13 PM   #32
curbdog17
Mini Van
curbdog17's Avatar
This may be the Gayest thing someone could say
Old March 14th, 2010, 12:45 PM   #33
Mr.Green
I can levitate!
Mr.Green's Avatar
Just curious.... How do you know this? Just a guess? Did you test this? Do you know the available torque of the Prius and its brakes? Have you ever driven a car with over heated brakes? Too much heat = brakes dont work (for most passanger cars).
I do believe that the guy is either lieing or a complete moron. I love how he tries to justify not turning off the motor becasue the highway was too curvey. Didnt turn off the motor until the cop car had him on his bumper. PFFfttt.
Old March 14th, 2010, 06:24 PM   #34
v2win
v2win's Avatar
Yes you can. Hold the start button down and it will shut the engine off you will lose power steering and the power brakes will go out eventually but you can still shut it off
There are some f bombs in this so watch the volume.
v2win is offline   Reply With Quote
Old March 14th, 2010, 11:03 PM   #35
SET2JET
SET2JET's Avatar
some
SET2JET is offline   Reply With Quote
Old March 14th, 2010, 11:11 PM   #36
ChadSmeltzer
ChadSmeltzer's Avatar
Out of curiosity I borrowed my moms Toyota today. At 60 with the gas to the floor, I hit the brakes and stopped surprisingly well, once it got into first gear it went just a bit further then stopped. You could also shut it off in either drive or neutral by holding down the On/Off button for 3 seconds, you lose power steering but it DOES NOT lock up. If you were going slow enough, you only had to hit the button quickly and it would shut off, even if in drive.
You can even start it back up in drive even without the foot on the brake, which I thought was kinda weird. Also, there was no way I could reach the gas pedal with my hand while in the seat, let alone at 90 MPH.
04 TJ - 35's, locked, 4link
ChadSmeltzer is offline   Reply With Quote
Old March 15th, 2010, 12:33 AM   #37
Blazin_wheeler
turtles like me
Blazin_wheeler's Avatar
so you took your moms car out today, beat on it and cooked the brakes, nice
Blazin_wheeler is offline   Reply With Quote
Old March 15th, 2010, 12:37 AM   #38
kj kyle
kj kyle's Avatar
thats ok, if it fucks up she can drive it into a wall, and get a new one
kj kyle is offline   Reply With Quote
Old March 15th, 2010, 12:40 AM   #39
Blazin_wheeler
turtles like me
Nuggets needs to tell the story about the time the gas pedal stuck in his Yugo again.
Old March 15th, 2010, 03:16 AM   #40
GreaseMonkey
Pew pew!
Because the torque that brakes create is much, much more than what engines produce.
I wish I had numbers on what torque a single disc brake can achieve, but unfortunately I'm having trouble finding numbers like that.
Regardless, take any vehicle and floor the gas pedal. Even up to 100 MPH. Then while keeping the throttle wide open, put the brakes to the floor. The brakes will win and the vehicle will slow down very quickly. There won't be enough heat in that time period for the brakes not to work. Passenger brake pads operate fine in the range of 300 F to 600 F typically. Racing brake pads are much higher than that. You'd have to do a lot of hot laps to start seeing those temperatures, or just lightly dragging the brakes over a good distance.
Page generated in 0.42444 seconds with 83 queries
