covering a jeep tub - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 11th, 2010, 03:27 PM   #1
nathanthegreat
not really
nathanthegreat's Avatar
Default covering a jeep tub
anyone use roll in bed liner for there fiberglass jeep tubs? what kind did you use and did it last? any info would be great. thanks
nathanthegreat is offline   Reply With Quote
Old March 11th, 2010, 03:28 PM   #2
nathanthegreat
not really
inside the tub and under
Old March 11th, 2010, 03:32 PM   #3
Pokerob
hug life
Pokerob's Avatar
i used herculiner for one of my jeeps (fiberglass), it was easy and help up nicely but that shit was scratchy as hell. I rembember scraping my knuckles on the floor a few times.
i personally wouldnt do it again unless it was a smooth finish.
good luck
Old March 11th, 2010, 03:33 PM   #4
nathanthegreat
not really
good to know thanks
Old March 11th, 2010, 03:35 PM   #5
mboies
BS MUDDERZ
mboies's Avatar
try the rattle can type, this is alot smoother than the roll on.
mboies is offline   Reply With Quote
Old March 11th, 2010, 03:45 PM   #6
nathanthegreat
not really
this is the stuff i bought. i was thinking i would like it to be some what thick. i heard herculiner was good, but not sure i watnt to loose my knuckles. i think duplicolor is thinner. anyone use duplicolor?
Old March 11th, 2010, 03:54 PM   #7
mboies
BS MUDDERZ
mboies's Avatar
try using a differant roller then what they provide you with.
Old March 11th, 2010, 04:05 PM   #8
nathanthegreat
not really
good call. ill probably go with herculiner. thanks
Old March 11th, 2010, 04:16 PM   #9
Pokerob
hug life
Pokerob's Avatar
herculiner has small rubber granuals or whatever in them so im not sure if a smooth roller would work or not.
i would do a test spot first and see what happens.
Old March 12th, 2010, 07:23 AM   #10
Kegger83cj7
Kegger83cj7's Avatar
The duplicolor rattle cans spray nice and the finish is smoother but it does not hold up to the rough stuff. I sprayed my lower portion of the truck and the rear bumper that I built for it and it is not holding up to the tire spray and hits to the bumper. It is a work truck and the bumper gets abused but I am not happy with it. I rolled herculiner on a previus bumper and you can't chip that stuff if you tried. it was on there for 6 years and looked new. go roll on not spray.......
Kegger83cj7 is offline   Reply With Quote
Old March 13th, 2010, 01:10 PM   #11
Wolf
Wolf's Avatar
can also thin herculiner with xylene and it wont set as rough
Wolf is offline   Reply With Quote
Old March 13th, 2010, 10:21 PM   #12
gotsand
Still Playing in Sand
gotsand's Avatar
We were not happy with Herculiner in the bed of my son's truck. It was like sandpaper and it ran down the side of his tan truck with black streaks every time it rained.
I used Duplicolor undercoating (rattle can) in the bed and wheel wells of my Samurai last summer. Not too bad. I put it on too thick all at once because I was in a hurry and it took forever to cure. It is wearing through in the footwells already but that is probably from putting it on too thick and it wasn't fully cured before I used it. Multiple thinner coats I think would have been better. If I had to do it over, I would probably spend the little extra and do the Duplicolor bedliner instead.
gotsand is offline   Reply With Quote
Old March 13th, 2010, 10:25 PM   #13
xj97sport
atv rider
xj97sport's Avatar
just orderd duraback .... ive heard good things
Old March 13th, 2010, 10:44 PM   #14
nathanthegreat
not really
thanks for the info
Page generated in 0.30745 seconds with 66 queries
