Alternator/Charging problems - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 10th, 2010, 08:40 PM   #1
mud22
mud22's Avatar
Default Alternator/Charging problems
I just put a new alternator on my 85 chevy c30 with a 454. The alternator doesn't charge very good at an idle, about 11-12 volts, and when I turn the lights or blower motor or anything electrical on the voltage drops down to 7 or 8 volts or sometimes lower depending on what is on. When going down the road the damn thing will charge at 18 volts+ with nothing on but will still drop down when anything electrical is turned on. Does anybody know whats going on?
mud22 is offline   Reply With Quote
Old March 10th, 2010, 10:22 PM   #2
Yota Bill
sounds like a possible voltage regulator problem...did you test the wiring before replacing the alternator? what was the previous one doing?
Old March 11th, 2010, 02:09 PM   #3
BigBlkYJ 355
U-Joints Fear Me
BigBlkYJ 355's Avatar
You should not have 18+ volts coming out. Is it internally regulated?
Old March 11th, 2010, 04:17 PM   #4
pigfat
GONE COMMANDO
pigfat's Avatar
sounds like the regulator is bad.
pigfat is offline   Reply With Quote
Old March 11th, 2010, 07:08 PM   #5
mud22
mud22's Avatar
I do believe it is internally regulated. The biggest thing I don't get is why it won't charge at an idle.
Old March 11th, 2010, 08:58 PM   #6
Yota Bill
sooo....no answer on if you tested the wiring, or what the old one was doing?
Old March 12th, 2010, 07:50 AM   #7
BigBlkYJ 355
U-Joints Fear Me
I'd be a little more concerned about putting 20 volts to my vehicle. As said above, what was the old one doing, the same thing?
Old March 13th, 2010, 09:08 AM   #8
mud22
mud22's Avatar
No I did not test the wiring. How would I go about doing that? The old one was not doing the same thing, it just simply wouldn't charge anymore.
Old March 13th, 2010, 11:20 AM   #9
BigBlkYJ 355
U-Joints Fear Me
I would just swap the alternator again. I assume this was not new but remanned? If it is internally regulated its probably bad. Either that or you have something causing them to go bad fairly quick.
Old March 13th, 2010, 12:22 PM   #10
cmays03
BUILD BY ME NOT BOUGHT!
you might want to check the battery too. but it does sound like the regulator in the alt.
cmays03 is offline   Reply With Quote
Old March 14th, 2010, 12:56 AM   #11
Yota Bill
here is the schematic:
http://www.chiltonlibrary.com/conten...s/85776211.pdf
first make sure the fusible link is good (which I'm sure it is), you can do that by testing for battery voltage to the terminal label "2", which should also be cast into the housing of your alternator...that wire also connects directly to the charge wire (the heavier cable on the alt.) I would do a voltage drop test on the charge wire just to verify it is in good shape.
To test the the wire at terminal "1"...first off, is the charge light in the dash coming on when you turn the key on, engine off? Does the light go off when the engine is running?
Also make sure the alternator is well grounded to the casing. It grounds through the mounting of the alternator, which grounds through the engine ground straps, so I'm betting that is OK if you arent having any other engine problems. A bad ground to the engine would also show as slow or no starter speed, eratic guages, and ignition system problems.
this will test the basics, any problems found would need further testing, but if those few tests pass, then I would replace the alternator
Old March 14th, 2010, 11:07 AM   #12
mud22
mud22's Avatar
Thanks for the help.
Old March 14th, 2010, 04:26 PM   #13
Rob the plumber
Licensed master plumber
Rob the plumber's Avatar
How do you know the voltage output? Using the dash gauge or a meter?
Old March 16th, 2010, 10:00 PM   #14
mud22
mud22's Avatar
Just using the dash gauge.
Old March 16th, 2010, 10:39 PM   #15
Yota Bill
get a multimeter and test it at the battery or at the charge terminal of the alternator...dash guages are unreliable and inaccurite for testing purposes
Page generated in 0.80501 seconds with 68 queries
