Telling the difference between a 305 and 350 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 9th, 2010, 06:19 PM   #1
wave_crusher
I'll Direc your TV
wave_crusher's Avatar
Default Telling the difference between a 305 and 350
Is there a way to tell the difference between a 305 5.0L and a 350 5.7L? Obviously other than casting number and the VIN (the engine was swapped)
Just courious if there was a way, i'm pretty sure that they 305 and 350 use the same block just smaller bore and stroke....or something like that
Thanks
Old March 9th, 2010, 06:46 PM   #2
skife
skife's Avatar
casting numbers is pretty much it.
Old March 9th, 2010, 07:06 PM   #3
Michigan ZJ
On the older ones, the 305 had a wider harmonic balancer. But, I've seen a few 350 crate motors and GM remans that had the wider balancer on them.
Michigan ZJ is offline   Reply With Quote
Old March 9th, 2010, 07:10 PM   #4
whyme86
whyme86's Avatar
305s , 350s are internal balanced. 400s are external balanced
whyme86 is offline   Reply With Quote
Old March 9th, 2010, 07:24 PM   #5
Michigan ZJ
The 305 is internally balanced.
Old March 9th, 2010, 07:37 PM   #6
jbsjunk
Little Member
jbsjunk's Avatar
If it's 86 or newer, the displacement is cast in the drivers side below the head by the bellhousing. When they went to a 1 piece seal, they all turned to external balance on the flexplate. Before that, only the 400 was external.
Old March 9th, 2010, 07:47 PM   #7
Kodiak450r
Keep on truckin
Kodiak450r's Avatar
thats the fastest way to identify the 2. it'll either say 5.0 or 5.7
Old March 9th, 2010, 08:09 PM   #8
Michigan ZJ
They remained internally balanced. Some may argue that, but its true. There was a counterweight in the crank on the 2 peice seal set ups. When they come out with the 1 peice, there was no room for that counterweight, so they just welded some weight to the flywheel. They are considered internal balance because the harmonic balancer, in this case, is just a dampner unlike on the 400.
Old March 9th, 2010, 10:07 PM   #9
wave_crusher
I'll Direc your TV
So basically just the casting numbers and the 5.0/5.7L on the back of the motor?
Old March 9th, 2010, 10:10 PM   #10
jbsjunk
Little Member
jbsjunk's Avatar
Yup, on 86+ engines anyway. A good light and a mirror usually works if it's in the truck.
Old May 2nd, 2010, 10:57 AM   #11
370
370's Avatar
casting number or pull a head and measure the bore.. 350 is a 4in bore.. 305 is a 3.73in bore if i rememeboer correctly
370 is offline   Reply With Quote
Old May 2nd, 2010, 06:57 PM   #12
Yetti
Buy a Fiat! Save the UAW!
Yetti's Avatar
flex plates on 305s are smaller as is the diameter of the balancer. 350's use either a 6" wide flange or an 8" narrow balancer. the 305 ones are about 5" and wide. some even have a step on the ring.
Yetti
Old May 2nd, 2010, 08:03 PM   #13
370
370's Avatar
one a one piece rear main motor i think the flex plates are the same.. but i could be mistaken..
Page generated in 0.34065 seconds with 62 queries
