What year t-case? - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2010, 04:56 PM   #1
yj_hank
yj_hank's Avatar
Default What year t-case?
My son had the transfer case seize up on him and we need a new one. His is a 1987 suzuki samurai. Any idea what years will fit? Do you know of anyone who has one for sale or do you have one for sale? Any help would be appreciated.
Thanks,
Henry
yj_hank is offline   Reply With Quote
Old March 8th, 2010, 05:03 PM   #2
samurai2240
Adrenaline my drug choice
samurai2240's Avatar
the only difference on samurai t cases are the size of the yoke. (2 sizes) So as long as you have the yoke off his. Any samurai t case will work for you..
samurai2240 is offline   Reply With Quote
Old March 8th, 2010, 07:10 PM   #3
yj_hank
yj_hank's Avatar
Thanks for the answer.
Henry
Old March 8th, 2010, 08:25 PM   #4
scottie
Eye candy
scottie's Avatar
Well it might be more work if you get a 2wd T-case
So i'd recommend t-case from a 4wd samurai
Old July 20th, 2010, 11:51 AM   #5
zook94
Resident Jerkoff
zook94's Avatar
Location: Saginaw, Michigan, USA, North America, Earth, Milky way
Try checking to see if the rubber bushing under the shifter is crumbling/gone first, thats usually why they lock up. A new shifter "sheet" from any of the suzuki aftermarket vendors will fix the problem for $12. Remove the shifter, and reach in the hole and shift the case manually with a long screw driver, this will tell you if its really broke or not (probably not)
zook94 is offline   Reply With Quote
Old July 22nd, 2010, 07:01 PM   #6
93trackaddict
93trackaddict's Avatar
Default transfer case
I have an OTT kicker 2 Ill sell for 600 bucks
93trackaddict is offline   Reply With Quote
Old September 24th, 2010, 08:24 AM   #7
orionn
orionn's Avatar
As was mentioned, probably a bad shifter sheet most likely. Follow the instructions above. I have never seen a Samurai t-case sieze, ever. I have seen them split apart, but never sieze up.
The next biggest problems with the early (pre '91) t-case is the front ouput shaft being improperly shimed alowing the engagement ring to slip when you put it under a load.
You will notice a ringing or a ping sound like someone hitting an anvil with a hammer.
Hope that helps
orionn is offline   Reply With Quote
Page generated in 0.23095 seconds with 44 queries
