1977 K5 Blazer aka "SPARTY ON" - Page 8 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 25th, 2014, 02:26 PM   #141
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Got a set of 5.13's for the 60/14 combo, need to get a new carrier for the rear and a spacer for the spool in the front.
Old January 25th, 2014, 02:35 PM   #142
Hoss Blazer
!SPARTY ON!
Pair of 5pt harnesses for the front and pair of lap belts for the rear.
Put a remote trans cooler w/ electric fan to keep the tranny cool
Old January 25th, 2014, 02:43 PM   #143
Hoss Blazer
!SPARTY ON!
Got it done and entered into the Boyne Falls Polish Festival Mud Run this year.
Old January 25th, 2014, 02:48 PM   #144
Hoss Blazer
!SPARTY ON!
Started to drop the gas tank to put the fuel cell in the back.
Old January 26th, 2014, 08:02 AM   #145
Deuling
Sand Slut
Deuling's Avatar
Good update
Have pics of the cage to frame tie ins? I'm about to build my cage.
Deuling is offline   Reply With Quote
Old March 1st, 2014, 07:08 PM   #146
chasetheface123
chasetheface123's Avatar
Wheres the pics of that perty new cell you got?
chasetheface123 is offline   Reply With Quote
Old March 1st, 2014, 08:34 PM   #147
Hoss Blazer
!SPARTY ON!
Old March 1st, 2014, 08:39 PM   #148
Hoss Blazer
!SPARTY ON!
Also picked up a Hydro ram and fitting for the ram assist setup. Then did some swapping and picked up a reservoir for added fluid!
Old March 2nd, 2014, 10:13 AM   #149
chasetheface123
I dont know how youre going to mount that cell, but You can have the straps I have here if it helps any.
Old February 25th, 2015, 09:47 AM   #150
Hoss Blazer
!SPARTY ON!
Long over due update...
Old February 25th, 2015, 09:50 AM   #151
Hoss Blazer
!SPARTY ON!
Fuel cell....
Old February 25th, 2015, 02:05 PM   #152
Hoss Blazer
!SPARTY ON!
Start of new gauge cluster.....
Old February 25th, 2015, 02:10 PM   #153
Hoss Blazer
!SPARTY ON!
New steering wheel and quick disconnect coupler....
And seatbelts...
Tach and shift light....
Old February 25th, 2015, 04:50 PM   #154
Hoss Blazer
!SPARTY ON!
Picked up some new used tires....15/39.5/15 tsl's!
Had to do some grinding on the calipers to clear the 15" wheels....
Old February 26th, 2015, 09:48 AM   #155
Hoss Blazer
!SPARTY ON!
5.13 gear swap....
Old February 27th, 2015, 06:58 AM   #156
Hoss Blazer
!SPARTY ON!
Fuel tank shut off & new sump holes....
Old March 9th, 2015, 09:46 AM   #157
Hoss Blazer
!SPARTY ON!
Got some new heads for the bbc the other day to help bump up compression....
Gotta do some gasket matching now!
Old March 9th, 2015, 10:03 AM   #158
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Are you using the retainer clips that came with those pins on the steering ram? If so I would come up with a plan eliminate them before a stick or the local mud bog removes them and a pin falls out leaving you with no steering. Maybe weld a heavy flat washer on one end so it only comes out one way and drill a hole in the other end to use a big cotter pin.??
Old March 9th, 2015, 02:07 PM   #159
Hoss Blazer
!SPARTY ON!
Yep i talked to you about it before, it's on the list of things to do this spring before it comes out of the garage!
Old March 9th, 2015, 02:08 PM   #160
BigBlockBlazer
Axle breakin' 101
Haha I thought I remembered bitching about that before. Too many 's.
Page generated in 0.31609 seconds with 84 queries
