1977 K5 Blazer aka "SPARTY ON" - Page 7 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 30th, 2013, 05:14 PM   #121
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Some pics of the engine all in and final electric fan setup on the radiator
Old January 30th, 2013, 05:19 PM   #122
Hoss Blazer
!SPARTY ON!
Gauge setup inside, need to redo the toggle switch's. I need to add another one for the electric fan for the transmission.
Here's my ignition setup behind the glove box to stay clean and water proof
Also have to mount the fuel cell in the back before summer hits
Old January 30th, 2013, 05:34 PM   #123
Hoss Blazer
!SPARTY ON!
Picked up a spool for my Dana 60 front from another member on here. Ran into an issue trying to get the passenger side caliper off. Cant seam to get the shim and plate off because there rusted together....gonna have to take the die grinder to it....and hopefully not cut to deep
Driver's side came apart fine
Old February 10th, 2013, 09:58 AM   #124
Hoss Blazer
!SPARTY ON!
Well finally got the passenger side caliper spring and plate off! Had to take a die-grinder and cut it into a couple pieces then hammer the rest out.
So after that cluster i got the rest of the front axle tore apart and ready for the spool to go in
Here's a pic of how tight the passenger side exhaust is to the t-case and frame rail...
Old February 10th, 2013, 10:12 AM   #125
Hoss Blazer
!SPARTY ON!
This is what led to the evolution of the Dana 60 and 468.....
An outer stub and then another outer stub and inner shaft
And a sbc connecting rod...
Old February 10th, 2013, 11:38 AM   #126
chasetheface123
chasetheface123's Avatar
Whats going on with the rod?
Glad to see you finally got the caliper off. But I've yet to see you drive it around town more than once!
chasetheface123 is offline   Reply With Quote
Old February 10th, 2013, 12:00 PM   #127
Hoss Blazer
!SPARTY ON!
That's what happens when water gets into an engine...it doesn't combust like fuel does.... Ya i only drove it a couple times, when i hit 250 on the tranny temp gauge i stopped driving it. Didn't want to super heat it anymore. But this year it'll be out more hopefully....providing premium gas doesn't sky rocket like they say it will! It definitely likes to consume the fuel
Old February 13th, 2013, 10:19 PM   #128
xNMTBx
xNMTBx's Avatar
Nice rig hoss
xNMTBx is offline   Reply With Quote
Old March 24th, 2013, 10:12 AM   #129
Hoss Blazer
!SPARTY ON!
Going to put bed liner in the cab and remove the carpet.
Before..
After..
Stopped up @ Wally World and picked up a gallon on this for $44.
Old March 24th, 2013, 10:21 AM   #130
Hoss Blazer
!SPARTY ON!
Finally got the spool installed in the front axle.
Also took the doors off to do tube doors. I liked the Off Road Design doors but the price tag on them is $350 for the pair......not so nice of a price. So i decided to make my own fallowing there design, i'm gettting a 24ft tube of 1.5 1/8 wall square tube for $30.
Old March 24th, 2013, 10:23 AM   #131
Hoss Blazer
!SPARTY ON!
Couple more old pics....
Old March 25th, 2013, 07:24 AM   #132
firehawk
Live Action!
firehawk's Avatar
Does it run cool enough with your rad fan shroud? It should be spaced off the radiator with sides and top and bottom to get air to flow through the whole radiator. It looks like you have the metal right up against the radiator??? Could just be the pic though. You wouldn't want steel against aluminum either.
Old March 25th, 2013, 10:23 PM   #133
Hoss Blazer
!SPARTY ON!
What?
The fan shroud is the same distance as a stock fan would be. It uses the stock radiator cover to hold it in & the two old bolt holes holds the shroud the top. And I built brackets @ the bottom to hold it strait up. The temp stays between 190-210 & when I kick the fans on its drops to about 175-185.
Old April 24th, 2013, 06:27 PM   #134
Hoss Blazer
!SPARTY ON!
Been awhile since i posted any updates, so here it go's. Did the West Texas Mod to my power steering pump not just have to get the cooler hooked up and that'll be all ready to go.
Also got my toggle panel setup on my dash...
New trans pan installed..
And started getting parts for my crossover steering..
Old January 25th, 2014, 08:41 AM   #135
Hoss Blazer
!SPARTY ON!
So its been a real long while since i did an update on here...
I got a spare top from Iggy did a little cutting on it and came up w/ this...
With and end result of this...
Old January 25th, 2014, 08:45 AM   #136
Hoss Blazer
!SPARTY ON!
Got a new set of wheels and tires 38.5/15/16.5 monster mudders on DIY beadlocks..
Old January 25th, 2014, 08:49 AM   #137
Hoss Blazer
!SPARTY ON!
Finished up the steering upgrade w/ crossover steering and XJ shaft. With soon to be Ram Assist as well...
Old January 25th, 2014, 08:52 AM   #138
Hoss Blazer
!SPARTY ON!
Picked up a new 1'' carb spacer and a Holley Blue fuel pump and Fram fuel filter
And as extra fuel filter..
Old January 25th, 2014, 08:55 AM   #139
Hoss Blazer
!SPARTY ON!
Roll cage was painted and installed and tied into the frame...
Here's some pics of the finished bedliner came out great...
Old January 25th, 2014, 01:23 PM   #140
Hoss Blazer
!SPARTY ON!
I also put a EZ INCH lift on it to help clear the 38.5's, that's not so easy to install!
Page generated in 0.62011 seconds with 84 queries
