1977 K5 Blazer aka "SPARTY ON" - Page 6 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old September 27th, 2011, 07:26 AM   #101
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Got the short block done last night. Also got the cam dagree'd and the center line came in 1/2 dagree advanced, so there was no need to adjust it.
Old October 15th, 2011, 01:41 PM   #102
deerebowtie
Unchained
deerebowtie's Avatar
updates?
Old October 17th, 2011, 02:53 PM   #103
Hoss Blazer
!SPARTY ON!
I'm in the process of getting a new job right now so work has been slow but here's a little update.....Timing cover and oil pan on!
Old November 15th, 2011, 04:45 PM   #104
chasetheface123
chasetheface123's Avatar
Anything new? Its time to go snow boggin. Our builds should be done around the same time by the looks of things.
chasetheface123 is offline   Reply With Quote
Old December 26th, 2011, 05:25 PM   #105
Hoss Blazer
!SPARTY ON!
Well not a lot has been done got a new job and while cleaning the heads up i found a cracked intake seat.....! had to find a new one that ended up costing $40 shipped. But got a bolt in 4pt roll cage from a guy in Boyne for $100 gonna put that in then build back hoops and make it stronger.
Also got mufflers for x-mes gift from the wife. Dynomax 3" race mufflers!!
Old April 9th, 2012, 06:12 PM   #106
Hoss Blazer
!SPARTY ON!
Well got some things done finally!!! Ended up selling the 770 and getting a Holley 750 double pumper. Got one head back and installed onto the engine w/ the other one coming back this week. Got my dads old water pump off his 427 cause he's going electric.
ID:	91283   Click image for larger version
ID:	91284   Click image for larger version
Old April 9th, 2012, 06:42 PM   #107
chasetheface123
Its going to be snowing again before you finish this thing. Even MY truck is almost done....
Old April 9th, 2012, 06:54 PM   #108
Hoss Blazer
!SPARTY ON!
Ya but i have more into this engine than you probably have into your truck....
Old April 16th, 2012, 05:58 PM   #109
Hoss Blazer
!SPARTY ON!
Got the fuel pressure regulator mounted and ordering a gauge for it. SHOULD have the other head tomorrow...i hope!!!!
Old April 19th, 2012, 05:05 PM   #110
Hoss Blazer
!SPARTY ON!
BOOOM......head came in on now on the engine!!! Just need to install the valve train
ID:	91668   Click image for larger version
Old April 19th, 2012, 07:15 PM   #111
chasetheface123
Good point. Dick.
Old April 30th, 2012, 07:06 PM   #112
Hoss Blazer
!SPARTY ON!
ENGINE IS IN!!!!!!! Ran into an issue w/ the engine cross member....1/8 clearance! So we had to notch it, but that was an easy fix. Also got the fuel gauge on. Getting really close now!
ID:	92070   Click image for larger version
ID:	92071   Click image for larger version
ID:	92072   Click image for larger version
Old June 10th, 2012, 10:19 AM   #113
Hoss Blazer
!SPARTY ON!
Well had to make my own power steering bracket because i didn't want to spend the $70+ for a new one. In the process of building my own alt bracket as well. Ran into a problem w/ the top of the air cleaner sitting flush with the fire wall....time for a cowl hood!!
ID:	93784   Click image for larger version
Old June 10th, 2012, 11:16 PM   #114
chasetheface123
Need a hand with anything? I would be more than happy to stop over and help?
Old June 21st, 2012, 06:40 PM   #115
Hoss Blazer
!SPARTY ON!
Alt & power steering brackets are done! Going to get belts tomorrow and then that will be all done, just have to build electric fan brackets and it'll be ready to start. Also got the drivers side exhaust done tonight as well...
Old June 22nd, 2012, 08:35 AM   #116
Why YJ?
Don't be a wuss... HIT IT
Why YJ?'s Avatar
Hurry up! We need to go wheeling soon!!
2005 LJ comp cut, 1 tons, etc...
Paul
www.teamhodges.com
Why YJ? is offline   Reply With Quote
Old October 26th, 2012, 12:44 PM   #117
Hoss Blazer
!SPARTY ON!
Well it's been a while since I did and update....it's done driving around just still has a couple issues. First being that the tranny is getting to hot...maxed the gauge out the other day @ 250. And the other being brakes wants to pull when I brake. But other than that it runs really good and has tons of torque & power!!!
Old December 31st, 2012, 09:02 PM   #118
01bellmer01
01bellmer01's Avatar
Send a message via MSN to 01bellmer01
zoom zoom power?
01bellmer01 is offline   Reply With Quote
Old January 30th, 2013, 04:28 PM   #119
Hoss Blazer
!SPARTY ON!
Haven't done an update in a while so here's some pics more info.
Here's some pics of the hood w/ the 5" cowl on it....
Old January 30th, 2013, 05:07 PM   #120
Hoss Blazer
!SPARTY ON!
Collected some different tranny parts to try and keep it under 250 degree's. It got a little hot last year. B&M super cooler, electric fan, and B&M deep pan.
Page generated in 0.88165 seconds with 84 queries
