1977 K5 Blazer aka "SPARTY ON" - Page 5 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2011, 08:57 AM   #81
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Tore the old brakes off yesterday, what a pain in the ass! After 33 years the backing plate bolts were almost welded on they were so tight. Got the brackets on and the hubs ready to be installed on the rotors. Then drained the rear diff and found this....
ID:	75553   Click image for larger version
ID:	75554   Click image for larger version
Old March 8th, 2011, 09:08 AM   #82
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
I used to use those jack stands to hold up my Pontiac T1000.
Old March 8th, 2011, 09:12 AM   #83
Hoss Blazer
!SPARTY ON!
I had to steal those from my dad because my par is supporting the front axle right now, those red ones are old school!!
Old March 9th, 2011, 02:02 PM   #84
Hoss Blazer
!SPARTY ON!
Well got the hubs and rotors together today @ work, now just need to install them!!
Old March 19th, 2011, 11:10 AM   #85
Hoss Blazer
!SPARTY ON!
Got the rear axle done yesterday!!
ID:	76065   Click image for larger version
ID:	76066   Click image for larger version
Old March 28th, 2011, 07:44 PM   #86
Hoss Blazer
!SPARTY ON!
Got a shifter, thanks to BigBlockBlazer!!
Old April 12th, 2011, 01:50 PM   #87
Hoss Blazer
!SPARTY ON!
Got my electric fans in and mocked up. Dual 14" pulling 2,000cfm each and control module.
Old April 14th, 2011, 03:13 PM   #88
noeske14
Nice build!!!
noeske14 is offline   Reply With Quote
Old April 15th, 2011, 12:21 PM   #89
Hoss Blazer
!SPARTY ON!
Got some parts in yesterday from Speedway Motors. Got a tranny cooler and oil dipstick. Cooler is rated for vehicles up to 18,500GVW, so i think it will do the trick!! Also painted the valve covers!!
Old April 23rd, 2011, 07:55 AM   #90
Hoss Blazer
!SPARTY ON!
Got my pistons back from the machine shop Monday.
Went and got a tranny cover from Towstrapteaser.
An Auto meter tranny temp gauge
Also got the fans wired up to toggle switch's. Ones an auto switch, on position will kick it on @ 185 and then off again @165. Then when the other switch is just and on/off switch, that can run while the vehicle is off.
Old April 25th, 2011, 11:54 PM   #91
deerebowtie
Unchained
deerebowtie's Avatar
i like the color choice on the valve covers. nothing says bling like that paint thats made from ground up 100$ bills
Old May 14th, 2011, 09:54 AM   #92
Hoss Blazer
!SPARTY ON!
Well got the new fuse blocks setup and most of the wires run, just waiting for the rest on the engine to be done!!
Old May 20th, 2011, 08:15 AM   #93
Hoss Blazer
!SPARTY ON!
Got my fan shroud all mocked up and ready to transfer to the sheet of metal.
Old May 23rd, 2011, 06:58 PM   #94
Hoss Blazer
!SPARTY ON!
Finally got to mount the tires back on the wheels! The wheels painted the right way this time not rattle can. Was gonna try and balance them but...19.5oz!
Old June 13th, 2011, 07:51 AM   #95
Hoss Blazer
!SPARTY ON!
Been working 65 hrs weeks the last three weeks so not a lot of work has been done. Got the toggle switch's and tranny gauge mounted. Just waiting for my crankshaft to come back!
Old June 17th, 2011, 11:36 AM   #96
chasetheface123
chasetheface123's Avatar
Quit dicking the dog. On with it. Its summer, and it just rained a shit load.
chasetheface123 is offline   Reply With Quote
Old June 27th, 2011, 04:08 PM   #97
Hoss Blazer
!SPARTY ON!
Went to the NHRA drag races this weekend in Ohio and stopped @ the Summit store and got some parts. Got a Summit Ignition box w/ built in rev limiter and a new coil cap so i can run my Accel Super Coil!!
Old September 2nd, 2011, 11:38 AM   #98
Hoss Blazer
!SPARTY ON!
FINALLY GOT THE CRANK BACK and new flex plate!!!!!!! Also picked up a 19 gallon fuel cell from lil zj, so let the blazer build begin again!!!
Old September 2nd, 2011, 10:55 PM   #99
LILL ZJ
LILL ZJ's Avatar
Scotchbrite that cell with a red pad, and it'll look brand new. I woulda if i wasnt on my way on vacation.
LILL ZJ is offline   Reply With Quote
Old September 26th, 2011, 08:17 AM   #100
Hoss Blazer
!SPARTY ON!
Well went to plastic gauge the crank and it didn't end very well.....!When i drilled the holes for the splayed caps i drilled to deep and hit the oil galley. So we had to put some jb weld in the out splayed caps and put pipe plugs in the out holes. Now my block is a 2 bolt main again..
After that mess we got it back to the house and got the crank in, camshaft in, one piston installed and the timing chain on
Page generated in 0.59121 seconds with 84 queries
