1977 K5 Blazer aka "SPARTY ON" - Page 4 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old January 13th, 2011, 04:09 PM   #61
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Found a seal kit for the steering box that replaces the seal that was leaking in the old one. Gonna replace that seal in the new one just for piece of mind! Had to do some digging in the old GM books at work.
Old January 13th, 2011, 04:12 PM   #62
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Is there a motor in it yet?
Old January 13th, 2011, 05:52 PM   #63
Hoss Blazer
!SPARTY ON!
I wish.....haven't been able to get a hold of my machinist lately!
Old January 13th, 2011, 09:00 PM   #64
BigBlockBlazer
Axle breakin' 101
Please take the time to box the frame in from the firewall forward while the motor is out. I have had nothing but trouble trying to keep mine straight. The bid block, heavier axle, bigger tires, etc. put a huge strain on the c-channel frame. You will be sorry if you don't.
Old January 15th, 2011, 01:39 PM   #65
Hoss Blazer
!SPARTY ON!
Got ahold of him today he's having a hard time finding a rod because from what he tells me if a marine issue only rod. Gotta go to his show and pick one up and take it back to work and see if the parts department can order me one!
Old January 18th, 2011, 08:48 AM   #66
Hoss Blazer
!SPARTY ON!
Well we figured out that the rod was out of a Mercruiser. So i gave it to our parts department and if they can't find anything I'm gonna try a marine to see if they can maybe locate one. Did some engine work yesterday. Got the 4 holes drilled for the water passages. Also took a pic of the casting flash i had to grind out of the lifter valley. The 4 slots were almost completely closed and i ended up grinding them all open.
ID:	73339   Click image for larger version
Old January 18th, 2011, 08:51 AM   #67
BigBlockBlazer
Axle breakin' 101
This is the longest engine build ever.
Old January 18th, 2011, 08:55 AM   #68
Hoss Blazer
!SPARTY ON!
Tell me about it.....the hole thing that is holding us up is the damn rod!!! He tried honing it but he couldn't get the dark spots out of the end of the rod where end of the bearing go's! Both engines I've done have had one rod that was bad!
Old January 18th, 2011, 08:58 AM   #69
BigBlockBlazer
Axle breakin' 101
buy..........new..........rods.................... .......done.
Old January 18th, 2011, 09:03 AM   #70
Hoss Blazer
!SPARTY ON!
Trying to find one!!! Don't really wanna buy a hole set. This is what it looks like, the red square part is whats giving us problems. All the other rods have that part cut away.
Old February 1st, 2011, 10:24 AM   #71
Hoss Blazer
!SPARTY ON!
Well still trying to find a rod to get the engine together, but did do some work on the inside. Made a place to put the tranny gauge and other odds and ends if needed
ID:	73991   Click image for larger version
ID:	73992   Click image for larger version
Old February 8th, 2011, 10:00 AM   #72
Hoss Blazer
!SPARTY ON!
Finally found another connecting rod!!! Went down to traverse city to Thirlby and they had one!! Now i can continue on the engine build!!
Old February 19th, 2011, 10:39 AM   #73
Hoss Blazer
!SPARTY ON!
Got the new steering box put bolted back in place last night....wouldn't recommend try to do it by your self! I was a royal pain in my ass doing it alone! Didn't need to do much adj. on the steering wheel it right where it needs to be. GOtta take the block and get it washed and then the building begins!!!
Old February 19th, 2011, 07:40 PM   #74
chasetheface123
chasetheface123's Avatar
Hurry up. Its raining outside.
chasetheface123 is offline   Reply With Quote
Old March 1st, 2011, 09:46 AM   #75
Hoss Blazer
!SPARTY ON!
Well got the block back from the shop had to have the cylinder walls tapered to fit the 2.25 intake valves in. Should be getting the rest of the odds and ends for the engine in the next week or so!
ID:	75237   Click image for larger version
ID:	75238   Click image for larger version
Old March 1st, 2011, 06:43 PM   #76
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Wat? I never had to taper the walls on mine. I had 2.25I 1.88E On my .060 454. I know you are running a BBC but what is the final bore and what block.
Old March 2nd, 2011, 09:20 AM   #77
Hoss Blazer
!SPARTY ON!
It's a 70's block w/ final bore of 4.310. The Heads are 990's w/ the bigger 118 combustion chamber. The valves most likley wont hit but it's better safe than sorry....
Old March 2nd, 2011, 09:56 AM   #78
BigBlockBlazer
Axle breakin' 101
So is the gasket tapered too?
Old March 2nd, 2011, 10:30 AM   #79
Hoss Blazer
!SPARTY ON!
Matched to the gasket
Old March 7th, 2011, 01:15 PM   #80
Hoss Blazer
!SPARTY ON!
Look what i found on the side of the road.....thanks to Deerbowtie!!
ID:	75501   Click image for larger version
Page generated in 0.29623 seconds with 84 queries
