1977 K5 Blazer aka "SPARTY ON" - Page 3 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old June 24th, 2010, 08:51 AM   #41
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Update!!!! Tranny just got rebuilt, by Joe's Transmission in Boyne City. Block had to be decked .004 due to the high spot between #4-6 & 3-5. Soft plugs are now in, and got the new S A gear Doug Herbert timing gear set. Should be getting crankshaft back from being balanced w/ in the week. Short block should be complete soon!!
Old July 9th, 2010, 01:26 PM   #42
Hoss Blazer
!SPARTY ON!
Just ordered the Torque Converter and shift light!! Next will be the TH350 to NP205 adapter!! Then buy the rest of my engine parts!
Old July 9th, 2010, 02:04 PM   #43
liftedandgifted
liftedandgifted's Avatar
Get it done or mine will be done first. Of coarse mines been going on for about 5 years. No sense in hurrying.
liftedandgifted is offline   Reply With Quote
Old July 9th, 2010, 02:25 PM   #44
Hoss Blazer
!SPARTY ON!
Which one of your projects the blazer or rail??
Old July 14th, 2010, 06:08 AM   #45
Hoss Blazer
!SPARTY ON!
Well got some part from summit yesterday!!! Now just waiting on the AA coupler that Ironman offroad ordered me!!
Boss Hog Torque Converter 2200-2800 stall
Summit Racing dial a shift light
S.A. Gear true roller timing chain
Old July 20th, 2010, 06:37 AM   #46
Hoss Blazer
!SPARTY ON!
Well got my Advanced Adapter coupler in the mail yesterday. It'll coupler my 10 spline NP205 to my 27spline TH350. So i put the tranny and t-case together last night. Going to pick up the rest of my engine parts today after work!
Old August 6th, 2010, 05:58 AM   #47
Hoss Blazer
!SPARTY ON!
Just getting the last parts to the puzzle now! Had to get a new flexplate because mine was bent and had a little crack in it. It should be arriving today!
Old August 17th, 2010, 06:08 AM   #48
Hoss Blazer
!SPARTY ON!
Well still haven't got the rest of my engine parts, so i decided to do some body work. Trimmed the front fenders. Cut the rear part back so the tire wouldn't hit anymore and then cut the front part of the fender straight across. The passenger side turned out good them i ran out of batteries for my rayobi cordless sawzaw, so i had to get my dads craftsman to do the drivers side. It didn't turn out so hot, i cuts a lot faster than the rayobi one!! But it turned out ok. Also got the shift light mounted.
Old August 20th, 2010, 04:21 PM   #49
Hoss Blazer
!SPARTY ON!
Filled in the gap in between the fender and inner fender. Doesn't look perfect but it'll work for a mud toy!
ID:	66771   Click image for larger version
ID:	66772   Click image for larger version
ID:	66773   Click image for larger version
Old October 25th, 2010, 09:24 PM   #50
Heavy Chevy
Heavy Chevy's Avatar
Whats up fawker? any progress on the blaze latley??
Heavy Chevy is offline   Reply With Quote
Old October 26th, 2010, 06:21 AM   #51
Hoss Blazer
!SPARTY ON!
Not to much just waiting for my rotating assembly to be returned to me!
Old October 27th, 2010, 07:40 PM   #52
Heavy Chevy
Whos doin it for you? alpine?
Old October 27th, 2010, 08:12 PM   #53
KILLER"B"468
Yankabilly
KILLER"B"468's Avatar
Nice build but a questions
I hope that is not your fresh built trans bolted to the np205?
why are you running that intake and then a spacer as well? you are really taking away from your torque, which is what you need in mud.
Old October 28th, 2010, 03:49 AM   #54
4Bangler
Jackstand Wheeler
4Bangler's Avatar
Originally Posted by KILLER"B"468 View Post
....I hope that is not your fresh built trans bolted to the np205?.....
I was thinking the same thing....maybe his rebuilder tests transmissions through a mud hole after rebuilding....or maybe it's rebuild in a can???
Old October 28th, 2010, 08:27 AM   #55
Hoss Blazer
!SPARTY ON!
Nope, Steve Martin over in Charlevoix does all my dads and my engine work.
Yep thats my rebuilt TH350 bolted to the NP205....that pic was before i cleaned it off.
Don't know if i'm gonna run the spacer or not, it was on my old small block when i had it. Depends on if i have to get a 50cc Accelerator Pump or not, you need a 1/4 spacer to comp for it.
Old December 23rd, 2010, 02:28 PM   #56
Hoss Blazer
!SPARTY ON!
The wife ordered parts from Summit for my x-mas presents!!! So that means i can start working on it again
Old December 24th, 2010, 10:59 AM   #57
dustyxj
Troll Fourwheelers member
dustyxj's Avatar
Glad to see this build still moving forward..
dustyxj is offline   Reply With Quote
Old December 27th, 2010, 03:50 PM   #58
Hoss Blazer
!SPARTY ON!
The wife got me an tranny stick n tube, and a carb return spring, throttle cable and tranny kickdown cable bracket! Should be getting back to work on her soon, gotta change the steering box, patch the firewall where the heater used to be and other odds and ends!
ID:	72324   Click image for larger version
Old January 4th, 2011, 08:15 AM   #59
Hoss Blazer
!SPARTY ON!
Got some work done yesterday started patching the firewall where the old heater was. Pulled it out about 2 years ago and just out duck tape over it as a quick fix. So i decided to put a piece of metal over it. I'm gonna put my ignition box on it when i get it. It's gonna be mounted in the cab so it wont get wet. Still gotta finish drilling out all the holes for it but it a start
ID:	72636   Click image for larger version
ID:	72637   Click image for larger version
Old January 11th, 2011, 08:25 AM   #60
Hoss Blazer
!SPARTY ON!
Well got some work done yesterday. Got the rest of the hole drilled for the patch panel and also got the steering box off the frame so i can swap the new one in. Had to pull the coupler for the steering wheel off the old box and put it on the new one. Hopefully this one doesn't leak like the old one. Doesn't look like the frame is cracked anywhere so that's a great thing. Gonna try and beef it up a little bit there as well.
ID:	73047   Click image for larger version
ID:	73048   Click image for larger version
ID:	73049   Click image for larger version
Page generated in 0.33317 seconds with 84 queries
