1977 K5 Blazer aka "SPARTY ON" - Page 2 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 15th, 2010, 04:50 PM   #21
pistol pete
I do vinyl stickers
pistol pete's Avatar
i never wieghed my jeep, but its heavy all one ton running gear i understand what you mean though it still is lighter than a full size blazer
pistol pete is offline   Reply With Quote
Old March 15th, 2010, 04:53 PM   #22
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Originally Posted by whyme86 View Post
sweet how far from ohio r u hoss
Well from my house it took me 5 hours to get to college & i went to UNOH.
Old March 19th, 2010, 03:47 PM   #23
Hoss Blazer
!SPARTY ON!
Should be ordering rings and cam tonight!
Old March 23rd, 2010, 06:37 PM   #24
Hoss Blazer
!SPARTY ON!
Rotating assembly is getting balanced and lightened this week. Found a distributor from LiftedandGifted, thanks!!
Old March 29th, 2010, 01:53 PM   #25
Hoss Blazer
!SPARTY ON!
Order all the bearing, soft plugs, and ring Friday. Should be showing up sometime today!! Need to get more pics though.
Old March 29th, 2010, 03:03 PM   #26
liftedandgifted
liftedandgifted's Avatar
Don't count on the trans holding up if Joe's is building it. I now of a guy he did a turbo 350 for and the pulled it 11 times in a week and still didn't get it right. Not Impressed. Also did you get that distributor yet?
liftedandgifted is offline   Reply With Quote
Old March 29th, 2010, 03:11 PM   #27
Hoss Blazer
!SPARTY ON!
Who was it?? I've always had good luck w/ Joe and all of my friends have to. I just pm'd Eric to see if he was gonna be in the shop after i get out of work!!
Old March 29th, 2010, 03:12 PM   #28
liftedandgifted
That's who had the problems. He will tell you all about it.
Old March 29th, 2010, 03:32 PM   #29
Hoss Blazer
!SPARTY ON!
Ah ic
Old March 30th, 2010, 01:14 AM   #30
Schvin
Schvin's Avatar
I go there
Takes me 3 1/2 hours to get to school(Lima, OH for those who don't know where UNOH is), I'm from Grand Rapids
Schvin is offline   Reply With Quote
Old March 31st, 2010, 02:14 PM   #31
Hoss Blazer
!SPARTY ON!
Well got the bearing and gasket kits in today. Found out i gotta drill 4 holes in my block for water passages. Miner setback. Will be getting pics tonight!!
Old April 9th, 2010, 03:03 PM   #32
Hoss Blazer
!SPARTY ON!
Should be drilling holes in the block this weekend and ordering the cam.
Old April 29th, 2010, 04:57 PM   #33
Hoss Blazer
!SPARTY ON!
On the way to get the camshaft after work. Now can start assembling the engine!!
Old April 29th, 2010, 07:51 PM   #34
BuickBlazer455
Buick Thunder
BuickBlazer455's Avatar
Hey i see your putting the 770 truck avenger on. Great carb but sucks balls off the line unless you have a pretty serious built big block. I have the 770 also on a Buick 455 built pretty decent in a blazer and i have a horrible stumble off the line. I called Holley and talked to there "truck and street avenger specialist" and he told me that they have some check valve in the metering block that wont lift off until you get up in revs or have a pretty serious big block to pull enough air through the carb to lift the check valves off idle. Makes no sence to me since a 770 is not that huge of a carb. and he said there's nothing you can do about it all he did was offer me a reman 670 in place of my 770. but fukc that deal. Just thought id let ya know before you spend the 300 sum odd dollars on a 770. Might wanna call and talk to Holley first.
Sounds like the blazer is goin good man!
BuickBlazer455 is offline   Reply With Quote
Old April 29th, 2010, 09:57 PM   #35
pitbull2332
pitbull2332's Avatar
Have you tried to adjust the accerator pump? you can change the cams and get more fuel in there to overcome the stumble. Or try a 50cc pump kit.
pitbull2332 is offline   Reply With Quote
Old April 30th, 2010, 08:50 AM   #36
Hoss Blazer
!SPARTY ON!
New Camshaft
Single Plane Intake
Corvette Valve Covers
Torn Down NP205
Engine
Old April 30th, 2010, 08:55 AM   #37
liftedandgifted
50cc pump worked for mine. It's nice and crisp. sorry to add to your hijacked thread. How is the Blazer coming? That's a nice pile of parts.
Old April 30th, 2010, 09:54 AM   #38
Hoss Blazer
!SPARTY ON!
This one??
http://www.jegs.com/p/Holley/Holley-...43667/10002/-1
Old April 30th, 2010, 10:36 AM   #39
liftedandgifted
yes
Old May 1st, 2010, 11:41 AM   #40
Hoss Blazer
!SPARTY ON!
Gotta order some more parts now!
Page generated in 0.51045 seconds with 84 queries
