1977 K5 Blazer aka "SPARTY ON" - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 8th, 2010, 08:36 AM   #1
Hoss Blazer
!SPARTY ON!
Hoss Blazer's Avatar
Default 1977 K5 Blazer aka "SPARTY ON"
So last week i sold my 353 sbc and the SM465 tranny. On tap now is the BBC and TH350 tranny. I'm in the process of building the engine right now and also rebuilding the tranny.
Engine: 468
74" 2bolt vette block
Comp Cam Extreme 4x4 camshaft
Single plane Intake
750 Holley double pumper w/ choke horn milled off
Speed Pro forged dome pistons .060 over
Cast crank
Cast rods
10.1 compression
Tranny:
TH350
Shift kit
Art Carr shifter
T-Case
NP205 w/ fixed rear yoke
Axles:
Dana 60 front "spooled"
14 Bolt rear "welded"
4.10 gears
Old March 8th, 2010, 08:46 AM   #2
BigBlockBlazer
Axle breakin' 101
BigBlockBlazer's Avatar
Why a th350 when you can get a good th400 core to rebuild cheap?
Old March 8th, 2010, 08:48 AM   #3
BigBlockBlazer
Axle breakin' 101
Also why the manual valve body?
Old March 8th, 2010, 08:53 AM   #4
Hoss Blazer
!SPARTY ON!
Because the kit to change my NP205 10 spline is only 155.25 and the TH400 kit is 586.50. And i have all the parts already except the adapter.
http://advanceadapters.com/product/2407/50-5304.html
http://advanceadapters.com/product/1691/50-3201.html
Thats the only was they make the reverse pattern for the TH350 and full control of the tranny!
Old March 8th, 2010, 08:57 AM   #5
BigBlockBlazer
Axle breakin' 101
You will end up spending that $ in upgraded parts to get the th350 to live. They can be built to handle some serious power, but it takes some cash to do it. The th350 is a good light weight trans though.
Old March 8th, 2010, 09:19 AM   #6
Hoss Blazer
!SPARTY ON!
Well i happen to know a tranny guy really good!!
Old March 9th, 2010, 07:04 PM   #7
Hoss Blazer
!SPARTY ON!
Picked up a set of heads and intake today. Heads are rectangle port 2.25/1.88 valves. Ported w/ new valve job. New valves, springs, retainers, and keepers. Intake is a Professional Products single plane intake.
Old March 9th, 2010, 07:07 PM   #8
whyme86
whyme86's Avatar
Well i wanta see her done and hear her running keep up good work love the k5s
whyme86 is offline   Reply With Quote
Old March 9th, 2010, 07:34 PM   #9
Hoss Blazer
!SPARTY ON!
Thanks, someday i wanna get rockwells like you and BigBlockBlazer. But ya gotta take it one project at a time i guess.
Old March 9th, 2010, 07:39 PM   #10
BigBert
Gone Huntin'
BigBert's Avatar
How big are your combustion chambers that you're only at 10:1 with Dome pistons. I'm a 11:1 on my 383 with flat tops and a 64cc chamber.
BigBert is offline   Reply With Quote
Old March 9th, 2010, 07:48 PM   #11
Hoss Blazer
!SPARTY ON!
I believe there 990 heads but i'd have to check again there still @ the machine shop.
Old March 9th, 2010, 08:36 PM   #12
pistol pete
I do vinyl stickers
pistol pete's Avatar
that turbo 350 will live if its built right, i had mine rebuilt 6years ago its behind a pretty stout 383 stroker turning 44in super swampers and hasnt failed me yet
pistol pete is offline   Reply With Quote
Old March 10th, 2010, 11:46 AM   #13
Hoss Blazer
!SPARTY ON!
I was thinking the same thing, my friends dad owns joe's tranny in Boyne City. He's been doing tranny's for ever so i think he'll know how to build one!!
Old March 10th, 2010, 01:24 PM   #14
BigBlockBlazer
Axle breakin' 101
In a Jeep that is 2000+ lbs lighter, Blazers weigh 6100+-lbs in factory trim. Beefcake
Old March 10th, 2010, 07:33 PM   #15
whyme86
whyme86's Avatar
u tellem bigblock jeeps are overrated LMFAO
Old March 10th, 2010, 08:23 PM   #16
Hoss Blazer
!SPARTY ON!
Well that's gonna be 6100+ of pure hell then!!
Old March 11th, 2010, 07:27 AM   #17
BigBlockBlazer
Axle breakin' 101
Sorry guy's I was smoking crack, production weight was around 4600, mine weighs the 6100 lbs. Smoke 'em if you got 'em.
Old March 11th, 2010, 10:15 AM   #18
Hoss Blazer
!SPARTY ON!
Ya mine isn't @ stock weight anymore though either!!
Old March 15th, 2010, 06:14 AM   #19
Hoss Blazer
!SPARTY ON!
Should be getting my balanced rotating assembly back this week some time. Also should be getting pics of the heads soon as well.
Old March 15th, 2010, 03:33 PM   #20
whyme86
whyme86's Avatar
sweet how far from ohio r u hoss
Page generated in 0.46447 seconds with 84 queries
