rear cv driveshaft for cj - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 7th, 2010, 08:46 PM   #1
JUSS10
4given4x4.com
JUSS10's Avatar
Default rear cv driveshaft for cj
looking for a rear cv drive shaft i can throw in my jeep cj. just threw a new driveline in and I'm above the 15 degrees max angle. don't care about length, that can be changed, just don't want to change the yolks on my axle and T case. thanks
JUSS10 is offline   Reply With Quote
Old March 7th, 2010, 09:30 PM   #2
jeepers48
jeepers48's Avatar
It would still help if you gave us more info: CJ 5 or CJ 7, trans, how much lift? A running length would do.
jeepers48 is offline   Reply With Quote
Old March 7th, 2010, 09:32 PM   #3
JUSS10
4given4x4.com
JUSS10's Avatar
well like i said i will bring it to a shop to get it fit to length but I'm looking for something in the 20 inch range. going on a cj7 with amc 360/TH400/D300
Old March 8th, 2010, 11:32 AM   #4
JeepInABox
In too deep
JeepInABox's Avatar
I have one for $50, can get you measurements tonight.
Old March 8th, 2010, 11:37 AM   #5
JUSS10
4given4x4.com
JUSS10's Avatar
sounds great. do you know if it will work in a CJ? or do you need me to measure the bearing caps?
Old March 8th, 2010, 11:37 AM   #6
JUSS10
4given4x4.com
JUSS10's Avatar
also, what shape are the joints in?
Old March 8th, 2010, 11:55 AM   #7
JeepInABox
In too deep
JeepInABox's Avatar
I have 2 rear factory slip joint driveshafts and one dc shaft that all use factory ujoints
you may have to change a yolk on the t-case to get the dc shaft to work.
I would not run the old joints and they are cheap for the driveshaft shop to replace them.
Old March 8th, 2010, 01:26 PM   #8
JUSS10
4given4x4.com
JUSS10's Avatar
what is a dc shaft? as for the slip yolks, could the yolk at the end be removed? maybe some pictures would help. thanks
Old March 9th, 2010, 06:04 PM   #9
JeepInABox
In too deep
JeepInABox's Avatar
double cardigan (sp?) The transfer case yolk needs to take bolts from the t case side since the DC is threaded.
Still working on pics
Old March 10th, 2010, 04:43 PM   #10
JeepInABox
In too deep
JeepInABox's Avatar
DC shaft 29 3/4 compressed 32 1/2 extended $50
rear factory slip shaft $40 each
#1 16 1/8 compressed 18 3/4 extended
#2 25 compressed 27 1/2 extended
front factory slip shaft $40
26 1/2 compressed 29 extended
No overall pic but it has the thinner diameter shaft
Page generated in 0.29940 seconds with 53 queries
