Late model 97 and up 231j rear seal # needed - Great Lakes 4x4. The largest offroad forum in the Midwest
Go Back   Great Lakes 4x4. The largest offroad forum in the Midwest > 4x4 Talk > Jeep Tech > Jeep tech FAQ
Jeep tech FAQ Look here first!
Old March 6th, 2010, 03:53 PM   #1
Toncomb
Toncomb's Avatar
Default Late model 97 and up 231j rear seal # needed
So I just switch around the input and sun gears in a 231j in doing so I had to remove the rear output seal. The case I'm using is a 2000 231j case with the exposed shaft and rubber boot in the back instead of the long tail cone piece. Mine looks like this...
I need the # for the seal on the rear output under that steel cover at the end of the rubber boot.
Thanks for any help, all the F'in parts stores up here show ALL jeeps having the tailcone extension piece which takes a different one.
Originally Posted by Nuggets View Post
Broken jar in butt = Nature's way if dealing with the stupid.
Originally Posted by SweetLeah View Post
Seems that 1/2 these people need to use periods and the other half need to get off their periods.
Toncomb is offline   Reply With Quote
Old March 6th, 2010, 04:16 PM   #2
Toncomb
Toncomb's Avatar
The one the extensions styles take is a 4370. That is not the one I need.
Old March 7th, 2010, 12:22 PM   #3
Jeeperz Creeperz
GL 4x4 Vendors
Jeeperz Creeperz's Avatar
National 18108
Old March 7th, 2010, 12:26 PM   #4
Toncomb
Toncomb's Avatar
Thank you very much. The 18108 is a Napa # for anyone else looking.
Page generated in 0.18229 seconds with 35 queries
