lincoln weld pak 3200 - Great Lakes 4x4. The largest offroad forum in the Midwest
Old March 6th, 2010, 01:13 AM   #1
special k
special k's Avatar
Default lincoln weld pak 3200
just picked up a used lincoln weld pac 3200 today with the argon tank and regulator. any one have any experience with one? good welder, bad welder?
Old March 6th, 2010, 07:50 AM   #2
ChevyRacer1981
Throw'in turtles........
ChevyRacer1981's Avatar
Never had bad luck with a Lincoln yet except the old as hell POS one at work. But even that one has a good day here and there. Your going to want argon and Co2 thought for regular welding. C25 gas is standard 100% argon is for tig and aluminum mig welding.
Old March 6th, 2010, 08:04 AM   #3
knaffie
knaffie's Avatar
They are decent machines for thinner material. 1/4" is about the thickest you want to weld with it. You do need to get an argon / CO2 mix. 100% argon and MIG won't work at all. Either that or a self-shielded wire. Don't forget to switch polarity if you go with flux-cored.
Old March 6th, 2010, 02:03 PM   #4
special k
special k's Avatar
it's already got the argon/co2 tank full
Page generated in 0.14440 seconds with 35 queries
